please help with radius program
Likes Likes:  0
Results 1 to 8 of 8
    Jan 2020
    Ohio
    Default please help with radius program
    Could anyone please help me. I need to program a .141 radius into the face of a part on a haas st10. No Y axis or live tooling. Im using a .125 wide full radius groove insert in a holder that points directly into the face of the part.Im not using tool nose comp or anything fancy. Just line for line programming. I don't have much lathe programming experience. Just have to make 6 parts from 316ss. I know the inside dia of the radius starts at x.185 and out from there I guess .282 to make the .141 rad. Please help me! Any help would be much appreciated. Ive never generated a radius like that.
    Jul 2013
    Indiana
    3,274
    4804
    1651
    You're probably gunna have to put up a sketch of what you're doing so folks can have a look see. When cutting on the face depending on the depth and diameter you're cutting the radial clearance on top and bottom of the insert is more of a factor than anything. This is a top notch style insert?
    Brent
    Jan 2020
    Kentucky
    Quote Originally Posted by ohiomachiner View Post
    G01 X(startpoint) z(startpoint)
    G02 X(endpoint of rad) Z(endpoint of rad) R0.141
    The G02 code is a clockwise radius. If you want your tool path to be counterclockwise, use G03 instead. You have to use a little common sense to figure your start and end points. Just make sure the distance between the start z and end z are 0.141. The actual distance between the two x’s should be 0.141 too, but the value would be double if your X axis is diametrical.
    If your tool is 1/8” wide you could do it in two passes G02 and G03 and have the passes meet in the middle. It could be done a few different ways. If the radius is critical you need to be using rad comp.
    Apr 2018
    3,973
    1794
    Please toss up at least a napkin sketch of what you are trying to do ...
    Nov 2013
    Utah
    4,797
    1266
    2691
    If you touch your Tool off on the inside of X. Start at
    G0X.177; (.185-.016)
    G1 Z0;
    G2 X.209 Z0. R.016; (.177+.032)
    G1 Z..
    This probably won't throw an Alarm, but it also won't generate ideal results. Hopefully you get the most basic principle.
    R
    Sep 2010
    Victoria Australia
    3,850
    1536
    G1 Z0;
    G1 Z..
    R
    Hello Rob,
    Belated best wishes for the New Year.
    Maybe I'm not seeing the OP's part feature as I should, but how do you get the R0.016 Radius. I'm assuming a concave feature of 0.141rad. With a 0.125 wide, full radius tool, the R would be 0.141 - 0.125/2 = 0.0785.
    With the tool set as a Type 2 tool (typical boring bar setup) and a 0.141 radius face groove having a small diameter of X0.185, I get the following. The finish pass shows the true positions of the tool.
    Regards,
    Bill
    (0.0625 RADIUS FACE GROOVING TOOL)
    (ROUGH CUTS START HERE)
    G00 X0.5920 Z0.1250
    G01 Z-0.1310
    G04 X0.1
    G01 Z0.0100
    (SEMI FINISH CUT STARTS HERE)
    G01 X0.7290
    G01 X0.7290 Z-0.0625
    G03 X0.4550 I-0.0685 K0.0000 (or G03 X0.4550 R0.0685)
    G01 Z0.0100
    (FINISH CUT STARTS HERE)
    G01 X0.7490
    G01 Z-0.0625
    G03 X0.4350 I-0.0785 K0.0000 (or G03 X0.4350 R0.0785)
    G01 Z0.1250
    Nov 2013
    Utah
    4,797
    1266
    2691
    Quote Originally Posted by angelw View Post
    Hello Rob,
    Bill, I'd been waiting a long time for this. I thought you were wrong, but I was mistaken.
    R
    .141 is a radius not a diameter.
    Jan 2020
    Ohio
    Thanks for the help. I appreciate it. got it done using a g42 and tip 7.....
