Mech_kumar225
- Aug 19, 2020
Hi everyone,
I am machining polystyrene on a 3-axis CNC milling machine. if anyone could help me with some parameters like feed, rpm and what tools should i use??
My material is expanded polystyrene 80mm thick. i am thinking of using ball nose for curves and simple one flutes endmill cutter. but as you know higher spindle speed might burn the form. AS of now this is what i know and am looking to justify machining parameters to my supervisor so if anyone could shed some light on it will be helpful
thanks a lot
thanks a lot
