9106872762
- Jun 22, 2020
We purchased new hmc[ Doosan hm 1250 W] machine 6 months ago
Machine is fitted with heidenen linear scale.
We are machining injection moulding platens in which postining accuracy by boring is required within 20 micron (0.001") from centre hole.
when we machined 2 holes at 500 mm centre distance then in inspection on trimos height master we get centre distance about 499.940
All centre distances are 50-60 micron minus in both X and Y axis in all jobs over 500mm
i just checked geometey on 1 meter granite and all readings are fall within 30 micron so i do not know the reason behind this error.
Someone tell me to do laser calibration for improvment of positining accuracy.
So in this closed looped system with heidenen linear scale machine gets all readings from scale so pitch error in ballscrew effects positining accuracy of machine in closed loop system??
In india temperature variation is very high so all data for pitch error compensation vary from company calibratin(i think so..!!)
please give me some suggestion.
thanks in advance
thanks in advance
