Getting tired of 1/4 sec power flickers stopping equipment. Has anyone installed a industrial power conditioner? And did it work? Not sure if power conditioner is the term.
Thank you
Yah. Even wrote some books on 'em.
1/4 second is an age for a "conditioner" to pull through.
You would need an "UPS". "
No break" class power ELSE the machine stutters. Not much gained to keep only the brains alive if the spindle and servos hiccup while in the cut.
So ... yah need high enough capacity to carry the FULL load, hard at work, not idling, but not necessarily for long endurance. EG: Enough time to
abort and power-down to wait for a better time of day or day of week.
Even if you ruin one piece of work in progress, the more important machine and tooling survive, undamaged
Five minutes can carry a major telco / IS/IT "FM" site, and 20 minutes is all the battery banks are usually sized for, max, even as uber-critical as such facilities be.
.. but...
..only because the Diesels or gas turbines - plural, redundant - are online in a matter of a few SECONDS.
You cannot afford that, You don't REALLY even want to know what we have to spend on it.
But all
you need is time enough to do an orderly shut-down.
If that is "too often" and/or "too unpredictable".. Or "some combination of the above?"
Then your best "power conditioner" is probably space in Texas or Northern Idaho.
Might WISH that was a joke. But it is anything BUT a joke.
It should pay back the cost of the move in lower taxes and all other operating and living costs. Probably by year two, if not year-ONE.
Or even "in advance"!
For than matter, MOST other states have an advantage, and a GROWING one at that.
Even rust-belt-stained Virginia, Ohio, Indiana, and Pennsylvania. Illinois, or Maryland not, and New York or New Jersey may as well be classed as train-wrecks "in progress".
A "better place" doesn't
have to be "Trumpist" nor a "red" state, BTW.
Just 50%
less crushingly self-burdened and insanely end-Luser/bizness
hostile than Kalifornikya has become.
Can't boil a water shortage, even less a shortage of good sense, even less with no power to DO it - even if you
could boil an ocean off the back of yet-another forest afire
