markz528
Hot Rolled
- Sep 25, 2012
- Cincinnati
Not too happy right now with Atrump. In process of getting my new mill running - its mostly set up now. The PC has a hardware issue and I am waiting for the replacement unit. It still works but I have to manually turn the PC on as you can't change the bios. Not too good for a brand new machine.
Tonight I put air on the power draw bar for the first time. It did not go well. Essentially the drawbar was semi-seized to the spindle. When I engaged the air, the spindle was spinning and I could not hold it with my hand without major effort and the air motor was laboring real bad.
I took the power draw bar motor off to inspect it. The unit is a Maxi Torque-Rite. Did not see any visual issues but the bar was pretty much stuck. I messed with it quite a bit and it is now a lot looser but still not right. Without a holder, it takes a couple seconds of the air motor spinning before the motor does not labor at all.
I have never used a power draw bar before. I am used to a Bridgeport drawbar where the bar can be removed from the top without anything holding it.
This bar does not move vertically - acts like it is locked in place - is this normal? If it is normal, any idea how to remove the drawbar?
Was hoping to be able to make some progress with this tomorrow but if necessary will wait till Monday when Atrump support is available.
Any suggestions or feedback?
