I have some parts on a horizontal where I mount the raw stock lightly with something like a set screw or Mitee clamp pushing on it to hold while I drill holes in non-functional areas for mounting screws. There are already tapped holes below where I am drilling, and we put in socket head cap screws and then the part gets roughed.
I am using a coolant thru carbide drill and drilling hard and fast with 1,000psi TSC. The problem is that sometimes there is a little "pip" or disc of material that gets stuck in the tapped hole under the part when the drill breaks through the back of the part material. This happens on maybe 10-20% of the holes but it's a pain in the ass to poke out that pip before installing the screws. I would like to implement something to prevent it, as there are LOTS of parts and screws on this fixture and it would save operators a lot of time.
I tried adjusting feed/speed but can't reliably get rid of all the pips. The tapped holes the screw go into are blind and helicoiled. I do not have clearance to make the tapped holes through. I thought about making a tool that is just a nozzle (maybe just a single hole through or perhaps some cross-holes on the end?) hoping the coolant would eject the little pip? Or maybe coming back in with a smaller drill to poke the pip loose and flush it out? I dunno.. anyone ever solved this problem?
