Rmillerauto
- Jan 1, 2020
I have a 1998 haas vf3. I installed a MP8 probe and MI12 interface and a wired TS27r. I was given the easy set macro list 40120737.0C with VQC added. I do not have VQC graphic display as I believe my machine software is too old. Everything is working mostly. However the probe sets work offset G54 in the negative on the DRO then its balanced out on the offsets page. It works but doesn't say "0" on DRO readout when set. not sure if that's normal or a big problem.
also I would like a quick code call for outside features xyz. I have a call for inside pocket that works good and the calibration for outside worked but no p9023 a... easy call for it on my list. I assume maybe I could link single feature calls together wit Zxy moves in between to accomplish this all together ?
Next issue is The TS works only in single tool set manual option. I calibrated it For Z touch off but I can not run the radius calibration with out errors.(505 value stack error) anytime I edit any #'s in a macro (as pre the manual says to do) I get that error. nor can I run the auto toolset. if I run it as is, the machine wants to move all the way to the opposite side of X on the table away from the setter. then it starts to work but then of course "probe open" error.
I feel like I'm missing something super simple here Like I have the wrong macro list or I'm missing something on my machine (programs from haas) or a setting or something. Or number or #1 i'ma idiot. I have had very little help and I'm totally learning as I go. So if anyone wants to help me out that would be great I'll donate for your time
