Probing for C axis alignment
dcrace
Jun 26, 2002
U.S.A.
Posted this in the Haas forum but maybe someone here can add any insight...
It seems the Renishaw probing cycles included with our new UMC-500 do not include macro programs to probe & align the C axis, Having run other 5 axis machines with Fanuc and Mazak controls, that cycle was part of the 9818 macro. By specifying a "K" value, that would determine the probing axis. I do have a message sent to our local HFO but haven't heard back yet. Not sure why Haas wouldn't include this, especially with a 5 axis machine.. If anyone has any information they could share it would be greatly appreciated.
Thank you.
Renishaw Inspection +, supplied with Haas, does not support 5 axis, and has no slightest idea of existence of rotary axes. Although not explained in your post, seems that you are trying to align C axis while its rotary table is vertical, and in fact becomes A axis (rotates around X axis). By definition macro 9817 deals with configuration, but be careful while executing it. I personally would prefer to have full control on what is happening and to write small program (presented on forum several times), to perform this task.
There is a macro to load that will calculate the angle and set the c axis to zero for you
Don
Don
I don't see that macro in my manual.. Fanuc and Mazak use that orientation in the 9818 macro by specifying a "K" value. K 3. for example if the flat was along X and K4. if it's along Y. with the trunnion at B0.0
Sorry if I wasn't clear in my description.. trying to orient the C axis with the table perpendicular to the spindle (B0.0)
Renishaw updated the 9843 angle find macro to include an "S" input to update work offset, but Haas hasn't fully included them yet. Renishaw gave me a program to load and try. If anyone else is interested, I can forward it along.
This is what I use to “indicate” a part parallel to the x axis. Just jog the probe to the front left corner and edit the I value to however wide your part is. I have another program in memory to align c by probing 2 bores or webs.
you mentioned having a cycle that uses two bores. was wondering if you would be willing to share that
Do you have this program available?
Can you please upload the c axis alignment probing to Boers. I would like to see how you are doing that.
Thanks so much
