Problem with 5 axis matsuura - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21
    Oct 2007
    SPAIN
    3,642
    2067
    1345
    It's definitely a positional is it?
    ie when indexing, the part IS flat after axis lock, and the chamfer tool just takes off too much the one face from the "top" (which is the face that's furthest from centre of table/part?)
    Are you sure that when the table indexes it locks at C0 being flat and zero, and not locks at 1.5degrees or something random although repeatable?
    I've had this on a 4th doing peripheral work and it was a parameter... for 3x identical machines...OEM never set 1x parameter...
  2. #22
    Sep 2017
    Wisconsin
    801
    129
    438
    Theoretically, someone could have gotten in there and really screwed up the calibration using the EZ-5 or whatever it is called. Matsuura told me to never futz with it, that the machines don't move and one can do more harm than good LOL.
    boosted does G54.4 need to be called or is it turned on by parameter? I'm still stuck on the fact that I only see a G54.1 P call and no other 5-axis specific WCS or operating mode seems to be active.
    It does seem like we agree that either:
    1) the work piece is at COR on the C Axis, OR
    2) you require some kind of compensation function to be active
    Since the work piece is demonstrably not at COR (or it would cut right in the same plane as it was probed, A0.0 and C0.0) and since this code was spliced in (and doesn't have any visible compensation calls) we need to figure out what calls they are using in the rest of the program.
    I suggest the OP go into the program and search for G68.2, G54.2, and G54.4 and see what the other toolpaths are using.
  3. Likes empwoer liked this post
  4. #23
    Sep 2018
    402
    558
    172
    Quote Originally Posted by boosted View Post
    Hopefully somebody with more Matsuura specific expertise can chime in. I do know a few things for certain though.
    - They can definitely program from COR and probe to compensate for error. That is what WSEC is for. The probed values would go into the "shift" instead of the standard work offset page.
    - G68.2, tilted workplanes is totally separate from dynamic work offsets. They can be combined or used separately. Dare I say most (at least most IME) 5 axis fanucs are being programmed using COR and tilted planes.
    - Dynamic Work Offsets are the shit, and it is shocking that so few people are utilizing them.
    - WSEC or DWO are dependent on your COR being calibrated correctly (and recorded in parameters) to function correctly. This is probably not your issue here though.
    yes, but you have to put in the work shift values into the table...
    we run our LX160 using straight up DWO and its programmed that way, havent had any issues with it yet.
  5. #24
    Oct 2006
    New Hampshire
    188
    79
    46
    I see G68.2 in that program which but I see no dynamic Work offset. Nothing in the probing sub says that the updated info is going into WSEC.
  6. #25
    Jan 2014
    Oregon
    321
    52
    168
    Fanuc gives access to the WSEC table as macro variables. Lot's of folks are writing probing routines to automatically handle small corrections with WSEC. Without seeing all of the code, it's really hard to speculate what's going on in that regard.
    As Rick said, my understanding is that there still must be a G54.4 called after the G54.1. I was speculating that perhaps Matsuura was doing something unexpected there.
    To the OP; it's time to start familiarizing yourself with 5 axis methodology, and that Fanuc programming manual. There are so many things that could potentially go wrong here, that it's going to be really difficult to diagnose over the internet. I think you are either seeing a programming error, or a combination of physical and programming errors.
    Personally, I'm a huge fan of starting from zero. Check that the COR is correct, and that your work offsets are in the correct spot after probing.
  7. #26
    Jan 2010
    Gilroy CA
    4,387
    3169
    2450
    Looks like the problem is the post. It is not outputting G68.2 for A0C0 Positions
    aka (TOP) does not call g68.2 so if your part is 1.00 off in X and 1.00 off in Y you will have a problem at A0C0 but your side operations will be correct.
    Have your post guy make sure to force G68.2 during all operations even if its 0 angle change it will still affect XYZ shifts from workoffsets
  8. Likes JMC liked this post
  9. #27
    Sep 2017
    Wisconsin
    801
    129
    438
    OP did you get this sorted?
  10. #28
    Jan 2020
    CANADA
    Alberta
    7
    Yes, sorry, i got it figured then forgot to come back with an update. Unfortunately as far as i know we dont have CAMplete. And if it had a licence fee they almost certainly never used it here. We have gibs but i dont really use it, so far its been simple enough work to just write the code. I beleive the problem was not having a g68.2 for the top of the part as a few people mentioned already. I think what happened was the guy who used to work here before me was probing these parts at 90 degrees and didnt leave any notes in his programs about his setups, so like a sane person i probed all the tables at 0 degrees. I didnt realize without the g68.2 the machine wouldnt know where the part is at 90 degrees. I thaught before that it was only for tilting the table on its c axis and not the b.
  11. #29
    Jan 2014
    Oregon
    321
    52
    168
    Quote Originally Posted by IconoclastAl View Post
    Just want to clarify that this is the issue. The top plane still doesn't need a G68.2, and adding a blank G68.2 shouldn't fix anything.
