SigurdACVW
- Aug 16, 2013
- IL
This is a feature that I'm trying to program. It's .500" spherical radius.
I'm on a 2-axis seat of Mastercam 2021, and programming from the solid model. The face of the radius is the drive surface. I can get through the flowline parameters and see the toolpath. However, when I go to backplot or verify, neither function will work. The tool doesn't appear, the slider on backplot won't move, and verify doesn't display anything either. I've attempted to create a surface from the radius face, but to no avail. I've used surface finish flowline with this 2-axis seat before. What could be going on? Is it the hole that's causing problems?
