Problem With Fadal VMC 4020 HT
Likes Likes:  0
Results 1 to 3 of 3
    Oct 2019
    Ohio
    Default Problem With Fadal VMC 4020 HT
    I am having a weird problem with Fadal VMC 4020 HT with Fadal CNC 88HS controller. I made a program to cut pocket with 2"X1" with 0.2" deep. The program runs all the way. But it cuts a pocket of 3.5"X1.5". I checked fixture coordinate and inch parameters. Somehow it is adding or multiplying a factor or coudn't be able to read inch value. Is there anyway to calibrate the machine tolearn inch values. Any suggestion or solution will be highly appreciated.
    Jan 2015
    Missouri
    1,261
    221
    794
    Hand coded?
    Sep 2010
    Oklahoma City, OK
    5,234
    960
    2244
    Please post your code. Those ratios don't scale so I dont think it's an issue with cutter comp.
