Problem with FANUC 16i-MA
Likes Likes:  0
Results 1 to 14 of 14
    Aguascalientes, Mexico
    13
    Default Problem with FANUC 16i-MA
    Hi everybody.
    I have a problem with a program in fanuc 16i-MA controller.
    The program starts normally, but when the program reads the first G01, the program doesn't jump to the next line.
    The system doesn't show any alarm
    Could anybody helps me?
    Mar 2005
    Silicon Valley, California... + other states & several countries on 3 continents
    2,100
    41
    Can you post that section of the code and what machine is this?
    13
    the line is this
    G1 Z38.0 S2000
    i have a mori seiki SH-500
    May 2010
    Warren, PA
    57
    you need a "F"
    13
    Sorry instead "S" is "F"
    the line is G1 Z38.0 F2000
    May 2009
    wa
    271
    8
    Quote Originally Posted by GMoreno View Post
    The feed rate is probably too fast. Is this a lathe or a mill?
    Try F20.0 or is it in mm????
    Dec 2007
    Southeastern US
    6,401
    845
    2806
    Silly I know......but Is the feedrate override at 0% ?.......
    Doors closed?
    Machine Lock on?......
    Run it again, when it hangs press the 'pos' button and see if it's showing any 'remaining distance' for Z.
    Nov 2005
    1,577
    19
    191
    Check for a G94 somewhere in your program before that line, make sure it is there. Use a decimal place at the end. Is it not moving at all or is it moving very slow?
    Husker
    Feb 2007
    Ridgefield, WA
    1,112
    134
    538
    Try posting a bit more code. It's possible that the machine is doing something else in the background and it's waiting for a confirmation signal to confirm the event before continuing. Something like putting a tool away after a tool change, and the tool changer hangs up or times out for example...
    13
    Quote Originally Posted by huskermcdoogle View Post
    Husker
    The machine doesn't move.
    The part of the program is
    N1
    G21
    M98P9005
    M98P9010
    G0G80G40G91G30Z0
    G0G91G30X0Y0
    M11
    G28B0.0
    M10
    IF[#147EQ1]GOTO2
    IF[#147NE1]THEN#3000=99
    IF[#1000EQ1]THEN#3000=93
    N2
    M1
    N60(N6 M14 PORTING TOOL)
    T06
    M6
    M8M88M80
    (G0G90B0.)
    IF[#5024NE0]THEN#3000=10
    (PART #1)
    G0G90G54.1P21
    G43H6X91.1Y16.7Z68.0T07M3S11500
    Z62.0
    G1Z38.0F2000.0 ----THIS LINE ISN'T EXECUTE
    G0Z90.0
  11. #11
    Nov 2005
    1,577
    19
    191
    N1
    G21
    M98P9005
    M98P9010
    G0G80G40G91G30Z0
    G0G91G30X0Y0
    M11
    G28B0.0
    M10
    IF[#147EQ1]GOTO2
    N2
    M1
    T06
    M6
    M8M88M80
    (G0G90B0.)
    (PART #1)
    G0G90G54.1P21
    Z62.0
    G0Z90.0
    Insert a G94 after the G1.
  12. #12
    13
    i forgot to mention that this problem is ocational and the system never displays any alarm
  13. #13
    Nov 2005
    1,577
    19
    191
    I think I got it Next time it does it check in your custom atc screen to see if you have tool change door close confirmation. If not you either have a prox going bad on your cylinder, or it needs adjustment.
    Husker
  14. #14
    13
    Husker
    Ok, let's me check that....we also think it is a problem with temperature...but i'm not sure.
