problems communicating with brother tc 324 n
Likes Likes:  0
Results 1 to 6 of 6
    Jul 2018
    BELGIUM
    22
    Default problems communicating with brother tc 324 n
    Hi ,
    recently we bought a Brother tc 324 N with brother cnc 630 control .
    We are facing some problems when we try to communicate with this machine using cimco edit 5
    this is a piece of the code we get when we try to output a program that is still in the brothers memory :
    %:NM5276 S;@ -33.700* -85.550* 104.815D50.*A4N-87.6*0.N-175.1*.2N-262.65*.1F2G9*1G3*1*1*5.*0.8*6._0.`3*2*90.*39.e1*6 .*0.*25.f-20.*5.5C100*100G9*2G10*2gij4ku 1 10.00.05 2 7.00.03 14.00.08 3 15.00.03100.00.12 4 12.0
    i have these setiings on the machine :
    connected to : computer
    baud rate : 9600
    parity : none
    stop bit : 1
    character length : 7
    response start time :60
    communication : LINE ( RS/CS)
    DC1 :17
    DC2 :18
    DC3 :19
    DC4 :20
    DR SIGNAL CHECK : yes
    communication end DC3 CODE : No
    output tape feed : yes
    settings are checked on cimco and are the same as these .
    what would i be doing wrong ?
    thanks
    Dec 2013
    903
    265
    539
    Is the machine conversational or g-code language? The older machines (pre A00 control) were ordered one way or the other. put up a picture of a program in edit or memory mode or a picture of the keyboard and I can tell you if you don't know.
    Oct 2016
    Florida
    380
    899
    239
    I would check for bad ground (needs to be clean for RS232), hook an oscilloscope on the R/T lines of the RS-232 and make sure pulses are clean referenced to RS-232 ground.
    After that look for crap connections. All connectors should be shiny clean, if covered in dust or anything worse, OH OH
    Jul 2018
    BELGIUM
    22
    Quote Originally Posted by BROTHERFRANK View Post
    Hi , thanks for your reply ,
    this is my keyboard
    Jul 2018
    BELGIUM
    22
    Quote Originally Posted by Pathogen View Post
    thanks , i will check that .
    Dec 2013
    903
    265
    539
    Quote Originally Posted by VPS BVBA View Post
    this is my keyboard
    Looks like Conversational to me. RS232 will only be useful to back up programs. No offline editing or CAD/CAM. If you are interested, you should check with your local Brother parts and service support. They may be able to still get the hardware to convert it to G code for you.
