I've run this on XP for years with no problems. I am forced to use Windows 7 now as OneCNC no longer runs on XP. I cannot get TNCRemo to work on Windows 7. I've tried both 3 and 3.3 revisions with similar results. It installs with no errors, everything looks good but it will not transfer files to the control. If the online converter is enabled and I try to transfer to the control, I get and error (can't download the DLL) from 3.0, and a different error (install error, can't activate the DLL) from 3.3 - these may be the same thing I suppose. I can transfer from the control, and it appears to be fast whether or not the online converter is active.
If I try to transfer to the control with the online converter not active, it appears to attempt to transfer very slowly, makes very little progress, and then fails and looses the connection. The file on the control is created but will show zero bytes. In fact there are some lines transferred, then a bunch of error lines, then it ends. This file cannot be deleted from the control ("Access denied") until the control is restarted.
I can go back to exactly the same version of TNCRemo on XP and it still works fine.
Any ideas?
Any ideas?
