Hi All,
First post here just after some advice, I’m relatively new to CNC machining.
We have a new job at work, where we are required to machine two edges at 200mm and 300mm as square as possible. When machining the parts we have managed to active a squareness of less than 0.005mm on the machine but as soon as the part is unclamped the part is springing to around 0.1mm at the most. Does anyone know anyway to get around this. The current strategy is a 0.5mm step over climb milling.
Any help much appreciated, can provide more info if needed.
Thanks in advanced for the help.
