Kallam
Cast Iron
- Feb 11, 2006
- South Carolina
Im profiling 1018 dom tube need to use a vnmg 331 insert. The part is to long to use a larger radius due to chatter.
Can anyone recommended an insert they like in this size that has the geometry and grade get a very good finish in this material. I need to get under a 32 micro inch with the finish pass.
Also what is the difference between a 35 deg diamond and 35 deg Rhombic. Are the both the same.
I guess I am getting old It seems insert selection is getting harder to understand.
Tim
Tim
