Profit Milling
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Profit Milling
    Jan 2020
    Default Profit Milling
    Hello, I'm new in this forum (never in a forum before) and i'm a newbie at programming CNCs. I recently program a rough cycle using profit milling and even though the chips are flying and the tool can handle the the feeds and speeds, it seems like the machine shakes violently when doing small steps around the work piece. I know I can slow it down so the machine would not shake. Everything seems to be fine except the shaking of the machine. The shaking concerns me. If I don't slow down my rougher and the machine keeps shaking will the machine, spindle, ball bearings get damage overtime?
    Thank you
    Loui
    Jun 2006
    Thunder Bay Canada
    1,832
    577
    310
    Quote Originally Posted by Loui View Post
    Yes they will be damaged.
    Jan 2014
    Oregon
    353
    58
    200
    1 - Make sure that look ahead/shape comp is turned on and set appropriately. Most Esprit posts will require you to manually add a tolerance setting in the custom fields. VERY few people are using look ahead correctly, and it is absolutely required for HSM on most machines.
    2 - It's been a while, but I believe Esprit will allow you to add fillets to the toolpaths. Bigger fillets will lead to less "shakey" motion.
    Jan 2020
    Thank you all! I am using Esprit. I will make sure my settings are correct.
    Jun 2012
    Michigan
    10,546
    3585
    3750
    Qt:[machine shakes violently] can lead to broken cutters..
    Many speed and feed recommendations are for the very best conditions like best fixturing and heavy solid parts...
  6. Likes Bobw, Screwmachine liked this post
    May 2019
    653
    187
    284
    I don't mean this to sound critical although it may come off that way.
    How can someone have access to software like Esprit and be asking questions like this?
    Here I am stuck with Fusion, Solidworks and HSMWorks. Turning out good parts so there is no way I could justify the cost of something like Esprit, although I would love to have it.
    It is my understanding that with Esprit your maintenance agreement includes tech support and training??
    Jun 2012
    Michigan
    5,003
    4554
    3012
    Quote Originally Posted by Hardplates View Post
    Maybe they figured they would get a quicker answer on here? Who knows.
    OP what machine are you doing this on?
    What you're describing sounds like it can't handle direction changes at higher feedrates. Some machines can easily compensate for this, others cannot so you would just have to slow it down until the machine likes it.
    Also is your program using arcs whenever possible? Or a ton of tiny little moves?
  9. #8
    Feb 2014
    Sunny South West Florida, USA
    3,098
    11139
    3501
    This could be a dude with a tabletop router and a cracked version of Esprit...
    Just saying..
  10. Likes Mtndew, 5 axis Fidia guy, npolanosky liked this post
  11. #9
    Nov 2011
    CANADA
    592
    40
    182
    I'd love to see a table top router violently shake.
  12. Likes primeholy liked this post
  13. #10
    Aug 2013
    Chicago, IL
    927
    643
    352
    Loui - what machine, speeds, feeds, depth of cut, width of cut, and cutter are you using on what material?
  14. #11
    May 2019
    653
    187
    284
    Quote Originally Posted by TeachMePlease View Post
    Just saying..
    Fair enough
  15. #12
    Jan 2014
    Oregon
    353
    58
    200
    A lot of things are magically handled in post processing.
    Seriously, I will bet that less than half of Esprit users are setting look ahead appropriately. A brand new NHX can feed at over 2000IPM in cut, and it will rattle itself to death doing so unless look ahead is turned on.
    Esprit can give you a lot of control over look ahead, but many users don't know it's there. A lot of other CAM systems just do a half-ass job of handling it for you, and basically treat motion comp as either "on" or "off".
  16. #13
    Feb 2012
    1,411
    892
    1523
    Using a smaller cutter can help in some cases.
    Someone posted here a few years ago about slotting with an endmill just slightly smaller than the slot width. It was traveling just a few 0.010 back and forth, starving the ballnut of lubrication and subsequently destroying it.
    Same can happen with the thrust bearings.
  17. Likes wheelieking71, mmurray70, Philabuster liked this post
  18. #14
    Jan 2013
    Gilbert, AZ
    6,148
    7794
    7920
    Quote Originally Posted by Orange Vise View Post
    Never thought about that. But, it makes perfect sense now that you say it Eric! Gonna store that away!
    (bye-the-way, gonna need a couple vises soon! LOL)
  19. Likes Philabuster liked this post
  20. #15
    Feb 2014
    3,098
    11139
    3501
    Quote Originally Posted by SteveEx30 View Post
    I think the router guys call it "cutting".
  21. Likes wheelieking71, Mud, Screwmachine liked this post
  22. #16
    Dec 2008
    New York
    10,235
    2657
    Thank you
    Loui
    1) yes sudden tool failure can easily damage part and the machine costing easily over $10,000. worth of damage if not careful
    2) the most important factor usually is length tool sticks out of tool holder, length of tool holder from spindle face, dia of cutter. cutter and tool holder vibration limits there are usually certain hp and cutting force limits
    3) part and holding fixture vibration. obviously when hp used and cutting forces are high enough severe pounding vibration can loosen things up like a impact wrench can tighten or loosen a bolt even when turning force is not as high as it would seem. pounding vibration effects things
    4) machine limits both hp at spindle and the ability of machine to withstand cutting forces. obviously some machines might be limited to 1hp, 10hp, 20hp being used. obviously many parts and working holding methods and machines might not be able to hold over 2000 lbs of pounding cutting forces. everything has limits. you dont normally put 2 tons in a 1/2 ton pickup truck for example
    5) yes often cutting parameters are adjusted so you get less than 1% sudden tool failure rate. 1% failure is like driving a car and every 100 days you crash the car. 1% can be way way too high a failure rate. of course things are usually adjusted for high reliability. crashing a car makes the travel time longer not shorter usually. going too fast often makes things take longer when failures are taken in to account. if driving a old car at 100mph makes the car shake badly where you feel it might fall apart suddenly most people slow down even if car could go 100mph or faster. obviously machine you use effects things or limits
  23. #17
    Jun 2012
    Michigan
    5,003
    4554
    3012
    Quote Originally Posted by DMF_TomB View Post
    What in the fuck does your reply have to do with this guys question? You post the same shit every time and 99% of the time it's not helpful.
  24. #18
    Nov 2014
    Florida
    4,131
    1620
    1941
    Quote Originally Posted by Mtndew View Post
    If you read thru his posts (between the lines) it seems he is always trying to justify going slower. Whether it is tool length stickout too long, or "sudden tool failure", or bad clamping blah blah. Everything circles back to him doing everything the slow and *safe* () way.
    I am pretty sure Tom has never heard, or doesn't understand, the phrase "you have to break a few eggs to make omelets"
  25. Likes Mtndew liked this post
  26. #19
    Feb 2014
    3,098
    11139
    3501
  27. #20
    Nov 2005
    1,585
    19
    194
    ROFLMAO, but I think you need to revise it to break the eggs gently, and use low heat to lightly cook the omlette.
