mjk
Titanium
- Oct 20, 2005
- Wilmington DE USA
96 NTC vmc w/Omb control
Within the last 2 years the program will sometimes stop after an M8 call with the coolant pump not starting.
Sometimes after an M9 call the coolant will stop, and the program will not go another line.
NO alarms, just stops
Theses are programs that have been used many times.
Manual on/off on panel turns pump on/off without hesitation.
Today I tried adding a series of M8 and M9 commands to my warmup program that loops and will run continuously until I stop it.
It ran for 30 minutes without a hint of the coolant pump not going on or off as programed.
The pump contactor sounded like it pulls in and releases normally.
On one of the programs I was having a problem with I tried adding a G4 P2000 dwell to the M8 or M9 line and keeping them on a single lines without any other commands. That seemed to help.
Another I added optional stops and turned the coolant on/off manually from the panel
Getting ready to run a part that has 12 tools and I'd like to solve the problem as restarting a program is a pain.
Suggestions appreciated
Mike
Mike
