LP08SS
- Jul 10, 2013
- New York, USA
Im having an issue with our shops program storage. we currently use compact flash cards which worked fine up until recently. i was getting a 111 data overflow alarm but when i looked there was still tons of space left on the card. i did some poking around to find out compact flash can only handle so many writes until it needs to be split into sub folders. so my main question is can fanuc controls traverse the file path so that i will be able to have access to all of the programs under the different sub folders or am i stuck having to use a fresh flash card? I have 4 hardinge mills 2 with 18i-mb controls and 2 with oi-md controls. thanks for any help!
