Programming Help Ellipse
Likes Likes:  0
Results 1 to 11 of 11
    Jan 2013
    Ohio
    84
    29
    Default Programming Help Ellipse
    I'm attempting to program a simple part with a ellipse.
    Running a Anilam 4200T Setup, however I just can't seem to get the G code down.
    G70 G90 G0 X0 Z0 T0
    M41
    G24 S1600
    T4
    G63 S400
    X4 Z0.1 M2
    G73 W3 A0.1 C1 B1 J0.007 K0.005
    G0 X0 Z0 T0 M5
    03
    G0 X0 Z0.1
    G1 X0 Z0
    G05 X1.665 Z-4 I0.00 K-4.00 A1.665 B4.0 L0
    M99
    Its a very simple part I just can seem to get past the ellipse part, I keep getting a error of no center point.
    Just starting out "playing" and I'm looking to learn.
    Regards
    Aug 2012
    Portugal
    139
    64
    7
    You have 2 options:
    1) Do it point by point; the most points you have the best elippse you get... endless program...
    2) Create a macro... learn how or ask help for it, do the math and you get it...
    One thing is granted... it is very dificult...
    Dec 2002
    Pacific NW
    5,074
    8
    816
    Go to: CNC Services NW
    cncsnw.com
    Down the left side click on tutorials. There's a macro program for a Centroid control to mill an ellipse. Modify as needed for your control.
    On edit: OOPS, I just noticed yours appears to be a lathe part, isn't it?
    Sep 2005
    San Diego
    3,168
    488
    783
    If you want a TRUE ellipse, every "micro-point" along the way has to be generated. The formula is... (x^2/a^2)+(y^2/b^2)=1 [X squared / a squared + etc.=1]
    Put the formula in a spread sheet and increment the movement ? .002" and let it calculate maybe 200 points.
    Regards,
    Stan-
    Apr 2011
    NJ, USA
    469
    107
    104
    Just remember, the tool path to cut an ellipse is not a scaled up ellipse. I dont remember the math behind it tho.
    Jan 2013
    Ohio
    84
    29
    Yes this is on a lathe, not a mill. I was hoping that someone would be familiar with Anilam controls, as they have a G-code function that "should" act as a true ellipse.
    The Code for this function is G05, but I'm just not familiar enough with it to code it correctly.
    Feb 2006
    Republic of Texas
    2,410
    Quote Originally Posted by MwM View Post
    G70 G90 G0 X0 Z0 T0
    M41
    G24 S1600
    T4
    G63 S400
    X4 Z0.1 M2
    G0 X0 Z0 T0 M5
    03
    G0 X0 Z0.1
    G1 X0 Z0
    M99
    Regards
    You poor bastard, having to deal with a POS Anilam control.
    Couple of things:
    G70 G90 G0 X0 Z0 T0
    M41
    G24 S1600
    T4
    G63 S400 This isn't supposed to be g96 s400 for CSS?
    X4 Z0.1 M2 Should be X4.+
    G0 X0 Z0 T0 M5
    03
    G0 X0 Z0.1
    G1 X0 Z0
    G1 X4.+ Canned cycles will go berserk, error out, or do unexpected things if the last line of profile is not a single axis move perpendicular to profiling axis. (X for G73, Z for G74)
    M99
    You might also try to move the profile out in Z so that back end of the part is Z0. Thus G5 X1.665 Z1 I0 K1 A1.665 B4. L0. (Something in the back of my mind says A and B should be half the values you have.)
    This is just another example of an Anilam idea that just doesn't work.
    Jan 2013
    Ohio
    84
    29
    G70 G90 G0 X0 Z0 T0
    M41
    G24 S1600
    T4
    G96 S400
    X4 Z0.1 M2
    G73 W3 A0.1 C1 B1 J0.007 K0.005 Canned Area Clear Cycle
    G0 X0 Z0 T0 M5
    03
    G0 X0 Z0.1
    G1 X0 Z0 Start Of Part.
    G05 X1.665 Z-4 I1.4419 K2.00 A1.665 B4 L0
    G1 X4.2
    M99
    This is what I have put together thus far...and it still will not take it.
    No idea what I'm doing wrong.
    No idea if these would help at all.
    Feb 2006
    Republic of Texas
    2,410
    G70 G90 G0 X0 Z0 T0
    M41
    G24 S1600
    T4
    G96 S400
    X4 Z0.1 M2
    G0 X0 Z0 T0 M5
    03
    G0 X0 Z0.1
    G1 X4.2
    M99
    The program you pictured on screen: in the sub, add the line G0 X0 Z.1 at the start. Change the last X4. to X4.1. The statement on screen of "All dimensions are incremental" throws me. If they are indeed supposed to be incremental then B should be B-4.
    03
    G0 X0 Z0.1
    G1 X0 Z0
    G05 X1.665 Z-4 I0.00 K-4.00 A1.665 B-4.0 L0
    G1 X4.1
    Jul 2005
    SE Michigan, USA
    651
    266
    177
    I don't know your control, but I'll take a stab at it.
    G05 X1.665 Z-4. I1.4419 K-4. A1.665 B4. L1.
    or
    G05 X1.665 Z-4. I1.4419 K-4. A1.665 B-4. L1.
    I'm not sure if B should be - or +, but i'm guessing +.
    L is for CW/CCW (according to your help screen). Zero is neither. I'm guessing that you use a positive number for CCW, and a negative number for CW (probably doesn't need to be 1 or -1, but any positive or negative number [I'm basing that guess on how I'd write the macro {which is what you are dealing with}])
    BTW, when you make typos, while posting code for people here to look over, it adds unnecessary confusion. Examples:
    X4 Z0.1 M2
    03
  11. #11
    Feb 2011
    NY USA
    43
    7
    I would also take the M2 out of the 6th line down. M2 = M30 = End of Program. I would think that makes the control stop right there and not process anything after that. M2 or M30 goes after the main program, but before the subs when you are using them.
