nightsky84
- Nov 26, 2019
Hello all again!
I am currently new the macro programming, but with a little help from the boss I'm starting to figure it out. My question is we have a quick setter that comes down so we can touch our tools off. If I am programming this to do it by itself should I use machine coordinates or the coordinates from the tool offset? I think I can use the machine coordinates for the tool setter so I know where it's at but then if I call up a tool and use the machine coordinates for it it may not go in front of the setter and crash into it. Where if I use its tool offset then I can tell it to go to an inch or so in front of the tool setters location and it not crash, but then if I were to change to a different part and change the Z offset on my work coordinates that location would change and could make the same tool crash. I don't know what to do and I need some insight on what I need to do. I just need to get it to where the tool checks itself and doesn't crash into my tool setter.
