Proper torque on lathe chuck jaws
Results 1 to 8 of 8
    Aug 2014
    Noble, OK
    809
    66
    162
    Default Proper torque on lathe chuck jaws
    Our 12" Bison has no documentation but it's a Kitagawa-interchangeable model, so I looked at the Kitagawa B212 manual. It says the M16 jaw bolts require 185 ft-lbs (250 N-m technically). It felt like it took 500 ft-lbs to break them free . After adjusting them, I retightened with a 1/2" breaker bar and one or two grunts, so probably in the 100 ft lb range. This is on a brand new lathe, new chuck, new jaws, etc. What's reasonable for tightening them back? Mfr spec or something a bit more reasonable.
    Dec 2002
    Granville,NY,USA
    3,901
    300
    400
    I've taken to using a torque wrench tightening chuck jaws and mount bolts. The M12 get 84 LB-FT on my lathe. Other than piece of mind it does seem to increase consistency when remounting soft jaws.
  3. Likes Limy Sami liked this post
    Jan 2007
    Norfolk, UK
    17,410
    13091
    12754
    Quote Originally Posted by ARB View Post
    Having seen a chuck jaw come loose - because it was never tightened properly, at high RPM and throwing a large part in the process, (which only just missed a very young and green Sami ) I have always been very very careful over such procedures??
    As for the OP's 185 ft lbs, IMO is not over tight for an M16 Allen Bolt
  5. Likes ARB liked this post
  6. #4
    Aug 2014
    Noble, OK
    809
    66
    162
    Quote Originally Posted by Limy Sami View Post
    Over tight wasn't the question necessarily, but necessarily tight.
    I'll get a 1/2" torque wrench and go to work.
  7. #5
    Aug 2006
    Cape Cod, Ma
    411
    128
    78
    I torque my jaws using a 80lb torque stick on an air impact.
  8. #6
    Jan 2007
    Norfolk, UK
    17,410
    13091
    12754
    Quote Originally Posted by Jay Fleming View Post
    I think something may have got bit lost in the translation Jay, ….to us Brits if somethings ''not over'' - it's about right.
  9. #7
    Mar 2011
    Geneva Illinois USA
    5,430
    2180
    2018
    In situations like this, my advice is "tight as you can get it, then two full turns more".
    Tom
  10. #8
    Apr 2016
    Florida
    171
    146
    45
    https://www.holo-krome.com/uploads/7...edatachart.pdf
    These guys who make bolts say M12 should be about 120ft-lb and M16 should be 300ft-lb
    Torque Information : Fuller Fasteners
    These other guys who make bolts give figures about 20% lower for high grade hardware.
    http://www.kitagawa.com/en/mtools/in...00_v107_en.pdf
    And finally, kitagawa gives 79 ft-lb for M12 and 184ft-lb for M16.
    So it sounds like it's up to you, but kitagawa's numbers are probably safe enough and holo-krome is probably pushing the limits. Throw another ugga-dugga on it and call it good enough, just stand out of the plane of rotation!
