As long as I am reporting software issues, might as well do this one too:
If you have an SLX control and an indexer (though it probably also effects non-indexer lathes), be aware of a peculiar tool comp bug on this control. Drills are set up with the back edge and point as their reference X and Z and are comp'ed by their radius which must also be entered. This is different than how turning tools are entered. If you start a program with the indexer on a drill, ALL tools will be comp'ed that way during a position statement (not sure about actually turning). I.e. they will be one radius off. On the other hand, if you start the program with a non-drill indexed, a drill will be comp'ed as though it was a turning tool during a position, i.e., a position of a drill to X = 0 will result in the drill point being off by a radius. Positions (rapid moves) actually are not suppose to comp but they do in this sense.
I presume the same is true of a non indexer, if you start with a drill called out as the tool you would get the same result. Note that it only matters what is the current tool when you push Mode>Run.
For small radius turning tools you might not notice that it is off by the radius. The motion is correctly depicted in the tool path preview, and does what I say. Prototrak shrugged their shoulders and said they aren't maintaining the software in that control anymore, moved on to the ELX. No work around that I know of, except don't start the run with a drill as the current tool, and don't expect positions of drills to work as you might think.
