cj133
- May 8, 2014
- New Jersey USA
Hi all,
Very new to this but want to learn.
I'm working with a Prototrak SMX FHM 7 and want to use cad cam software with it.
Right now, it seems I have two options. To load G code into the machine as a .CAM file and have it convert it to it's own code, or to load a .GCD file and run raw G code. Is this correct?
Currently the guy I work with takes autocad files from me and loads them into Prototrak's software and then does what he needs to from there. I'd like to take it a step further than that.
I saw in the book it mentions running straight G code for complicated programs as well as if you want to use it as a full 3 axis machine but they don't really go into much detail.
I've got a lot of learning to do, but need someone to point me in the right direction if possible.
