Pull Stud Broke - Brother Spindle Trashed - Page 17
Page 17 of 26 FirstFirst ... 71516171819 ... LastLast
Results 321 to 340 of 512
  1. #321
    Aug 2002
    West Unity, Ohio
    25,441
    5690
    8104
    Quote Originally Posted by 2outof3 View Post
    Big D/K is very strict on the interface dimensions and using their gauging but draw bar force is not part of the standard.
    We have talked about this before. Brother does not publish draw bar forces so I am limited on what I can discuss. BBT will allow the user to push harder but it is not simple. It is not like a BBT30 is equal to a standard BT or Cat 40. at speeds below 12,000 or so, BBT will give you better tool life. It is helpful with reaming, longer tools and boring. It will allow for more aggressive milling but how much of your process needs or can be helped with BBT is just part of the equation.
    Well then, can we discuss how a fella is s'posed to know if his tension is OK or not if he doesn't know what it's s'posed to be in the firth place?
    I'm amazed that this would be a guarded secret in any way?
    Think Snow Eh!
    Ox
  2. Likes Finegrain, Mud, digger doug, Bobw, SND liked this post
  3. #322
    Sep 2014
    1,863
    1382
    1357
    Quote Originally Posted by barbter View Post
    When you say fast, i'm assuming you're talking running at the 16k for extended time?
    Out of interest, do the machines have a spindle chiller?
    The Feelers i had seemed very stable all round.
    The Robodrills i had (Model E) i noticed a little Y drift when constant running and a small amount of Z movement when running at 10k rpm constantly. But they never had a chiller.
    Ultimately neither were really a problem for me because we were a jobbing shop, so 25>50 was the norm, and qty 100 was a large run.
    Edit: - Ref the *how much difference does a BBT make over a BT* question, i've said before that i reckon it makes the spindle 30% more rigid.
    Not from a scientific calculation view, just a keen ear for cutting sound on one machine with and one machine without (both being identical models).
    Both Robodills were identical - one with BBT and one without.
    The first Feeler i bought was BT, and we upgraded that to BBT after the following 2x BBT machines were installed and running. So on both makes and types of machines, i had the same jobs running and could asses a before and after scenario.
    27,000 RPM is where you would see it most. No chiller and permanent grease pack spindles. Just an air blow to the back of the spindle to help keep it cool on the 27,000.
  4. #323
    Sep 2014
    1,863
    1382
    1357
    Think Snow Eh!
    Ox
    The drawbar is part of the spindle assembly not a separate unit. No need to worry about it. If you are losing force, it is a new spindle need. But because of the construction, that is just not something we see unless there is incredible cycles on the tool changer (think a couple million) or crashes.
  5. Likes Ox liked this post
  6. #324
    May 2011
    New Jersey
    2,296
    204
    1257
    I guess the basic jist is don't try to push these like a 40 taper machine. Seems they would be better suited for faster shallower cuts rather than blasting material with a large endmill. These sound like intriguing machines and when operated within parameters are fast, accurate, and reliable. But with anything, right tool for the job. 2 1.75 water lines may put out the fire, are easier to handle, and can pack a punch...but a 2.5 line is going to do it faster and easier...this would be on an external attack.
  7. #325
    Oct 2005
    15,668
    Your saying people with your spindle doo not replace the components like Bellvilles etc. ?
    And your not in control of the tool that engages YOUR spindle (funny how the customer pays for it the spindle, but you claim to still own it)
    But we cannot check to make sure the drawbar is working properly ?
    Sounds like a leased machine....or should be.
  8. #326
    Sep 2014
    1,863
    1382
    1357
    Why would you replace Bellville springs if they last a million tool changes?
  9. #327
    Sep 2014
    1,863
    1382
    1357
    Quote Originally Posted by plastikdreams View Post
    That is if your basic job is fighting fires. machine tools have tool changers because milling is one operation. It is about making money. If the machine makes more money for the investment what should you buy?
  10. #328
    Nov 2014
    Colorado
    2,888
    3413
    794
    With the J&M pullstuds / retention knobs you have to know the draw bar force so you can set the correct torque for the pull stud.
    Seems part of the drawbar force (in very broad strokes) corresponds to the types of gripper used.
    https://tacrockford.com/pdf/100.311/...ing-forces.pdf
    ^^^ Very broad specs for draw bar forces depending on gripper type. BBT 30 is not delineated from regular 30 taper.
    http://www.onlybusiness.com/Member/j...Chart_2017.pdf
    ^^^ With the J&M torque chart only specifies regular V 30, 40 50 tapers but not BBT.
    Seems the torque is 1/10 th of the drawbar force for generic 30 taper.
    I assume Brother specifies what the correct torque for pull studs needs to be for every spindle variant and corresponding type of pull stud.
    They sell (as you all know) draw bar force gauges, but you have to buy the one that's in the right range of forces :-)
  11. #329
    Nov 2019
    TURKEY
    5
    Vectric Aspire nasıl programdır ;
    Youtube üzerinde kurulumundan itibaren videoları
    YouTube
    Kurulum : YouTube
    Ve eğitim videoları : YouTube
  12. #330
    Sep 2014
    1,863
    1382
    1357
    Quote Originally Posted by cameraman View Post
    Pull stud torque is set by the tool holder maker not the stud maker.
  13. #331
    Nov 2014
    Colorado
    2,888
    3413
    794
    According to the research by J&M and Kaiser you have to set the pull stud torque in proportion to the draw bar force.
    Tool holders don't set specific drawbar force on a machine.
  14. #332
    Sep 2014
    1,863
    1382
    1357
    Kaiser will tell you how much force for tool holders for the Brother. As will MST, Lyndex Nikken, NT and others. When you buy holders, they will specify the torque requirements. Not Brother. I guess the assumption would be, the holder manufacturer is expecting you to use their pull studs.
  15. #333
    May 2009
    Wyoming
    3,270
    7940
    5268
    There's an old saying in auto racing: If you have to worry about whether a bolt is strong enough, you need a bigger bolt. This thread has gotten almost microtechnical in blaming the pull stud for wrecking Brother spindles when it's apparent that those machines are being used right at capacity and sometimes beyond. I am reminded of my first year doing warranty welding for the area Case dealer—I spent a lot of time putting various models of Case 580 backhoes back together and mentioned to my boss that those machines must really be junk. He laughed and said, No, they're just so good that they get regularly overloaded. There is not a lot of difference between this discussion and the recurring argument of roller-bearing ways versus box ways: do you prefer to hog metal off in one pass or zing it off in the same elapsed time using ten smaller passes? Each approach has its place. I will say I've never been blessed with a setup resistant enough that it could yank out a Haas CT40.
    But then I never tried an 8-inch flycutter...
  16. Likes bryan_machine, Bobw, mhajicek, SND liked this post
  17. #334
    Nov 2014
    Florida
    3,964
    1591
    1848
    Think Snow Eh!
    Ox[/QUOTE]
    Can we quote you on that million number please?
    I mean, I don't know what all affects the life of those washers, but I was at one place only a couple years and we replaced them twice in one machine. Let's try a little math while we are at it -
    1 part running say 3 minutes x 3 tools. So approximately 1 tool change per minute (not unheard of, right..?..) 10 hour day x 60 minutes per hour x 85% efficiency = 510 tool changes per day
    =1960 days = a little under 5 years. SO you would need to replace them if you are a high volume shop (those numbers assuming one 50 hour shift per week)
  18. #335
    Nov 2014
    Florida
    3,964
    1591
    1848
    Quote Originally Posted by Oldwrench View Post
    I've never seen (in person) a holder pull out from a 40 taper either. Either the machine alarms out, or a part gets thrown. I was one time running a "quick and dirty job" of facing down some parts about .12" or so. Cruising along fine with two passes (rough and finish) with a 2 or 3" face mill. Anywho, got a part that for some reason was about .25" larger than the rest. Loaded it up, hit cycle start, hear a god awful cut, turn and look then the machine quit on an overload alarm. Was trying to take about .38" the first pass. Didn;t like it so the machine quit. No wrecked spindle, no drama...
    Not blaming 30 tapers here (even though I think the OP's cut was too aggressive), just thinking something awful bad happened BEFORE that pull stud broke (and that is what made it break, not shoddy craftsmanship)....
  19. Likes Oldwrench, empwoer liked this post
  20. #336
    Sep 2014
    1,863
    1382
    1357
    Think Snow Eh!
    Ox
    =1960 days = a little under 5 years. SO you would need to replace them if you are a high volume shop (those numbers assuming one 50 hour shift per week)[/QUOTE]
    The 10k spindle lasts a long time. We just don't see a bunch of spindles needing to be replaced because of draw bar fatigue. I pulled the million out of my ass as a reference. We know how many machines we have in the US and how many spindles we go through. Not that many. Ask the users here what their experience is. I have a customer with a 12 second cycle and two shifts. 3 machines. I don't think we have done a spindle yet on any of the three machines after 6 years.
    We are going down a rabbit hole because of the prior experience of people buying less robust machines. Most Brother machines will make one part for their life. 7-10 years of 24/7 production with tool changes in the millions. They have to run or production lines go down. Worrying about Bellville springs is ridiculous.
  21. Likes Ox liked this post
  22. #337
    Mar 2013
    Oregon
    1,868
    757
    2204
    Andy's number is way low.
    I have one Speedio cell doing a 45 second cycle time steel part with 8 tool changes. 2 machines, sharing a robot/infeed system, loaded in about 15 seconds. Running 24/7 for the last 6 months. That would be ~ 1,800,000 tool changes so far, times 2 spindles.
    It is sitting next to a Robodrill cell, making the same part in 60 seconds of cycle time ( ::cough:: ) that has been at it for 2 years, so probably well into the 5 million tool change range.
    For all the bellyaching about these machines, the reality is that if you don't fuck up and crash them, they run with the reliability of a wood burning stove. Like I said, they print money.
  23. Likes Ox, 2outof3, J Gilles, Fal Grunt, BROTHERFRANK and 3 others liked this post
  24. #338
    Jul 2012
    Washington
    2,938
    1140
    1189
    I thought they were coil springs? Not belvilles.
  25. #339
    Dec 2013
    707
    230
    399
    Brother clamp shafts (draw bar) use a die spring not Belleville washers for the record. I have never seen someone need to replace the spring.
  26. #340
    Jul 2006
    Hillsboro, New Hampshire
    7,759
    1813
    5460
    Quote Originally Posted by BROTHERFRANK View Post
    Are the die springs so closely constrained in the spindle bore that runnout and unbalance are never an issue? In that case, what about rubbing wear?
