gkoenig
Titanium
- Mar 31, 2013
- Portland, OR
So, I'm now super confused on this...
Yamazen's kick ass installer guy was wiring up my new Speedio and we got to looking over the killer deal on some ER8 Lindex holders I snagged on eBay, and he took one look at them and said "These weren't used much, but someone overtorqued the pull studs." He based the diagnosis by the uneven wear pattern on the taper - top and bottom, nothing in the middle.
The obvious next question I asked was "Well, what's proper pull stud torque for a BT30?" His reply? 8-10ft lb!
That seems fuckin' low, Frank @ Maritool lists 25-35lb on his website. This man knows tooling, tapers, pull studs...
Low and behold, Frank's high-strength pull studs (J&M built) come with a little insert that says that with 800 pounds of retention pull, you need 8ft_lb on the pull stud. (J&M's Pull Stud Torque Guide: http://www.onlybusiness.com/Member/...tention Knob Tightening Torque Chart_2017.pdf)
In summary, multiple sources I tend to trust seem to be all over the map on this topic. 8ft_lb to 35ft_lb. What to do?
