Hey all
I'm at my wits' end trying to avoid chip welding while helical ramping into 6061. No other issues roughing or finishing, just ramping into pockets. I'm using 1/4" 3 flute at 10k RPM with a 5 degree helix and ramp diameter of .2375" (~95% tool width according to the CAM). I've tried both HSS and ZrN coated end mills, and feed rates of 20 and 40 IPM. Using air blast + koolmist for cooling, but it's clearly rubbing/melting the aluminum and getting welded onto every end mil I try Lowering the helix angle to 2 gives an ear-searing squeal which can't be good...
Again, works perfectly for other operations; can side mill all day long without issue or heat. Any ideas on what to try next?
