I know this thread is a month old. However.
In turning with carbide inserts I used 35 surface feet and .0015-.002 feed. Depth of cut .040".
Drilling went best with cobalt high speed steel 118 degree split tip drills. 10-15 surface feet, .001-.0015 feed.
A good rule of thumb is divide everything you would do in stainless by 10.
I believe Carpenter MP35N is the strongest commercially available malleable metal alloy. It consists of 35% nickel, 33% cobalt, 20% chromium, 10% molybdenum, etc. The material is usually purchased cold worked to a hardness of about 50 rockwell C, then machined, then age harden heat treated to achieve an ultimate tensile strength of 300kpsi +.
Still looking for some bar ends or a couple feet of 1-1/8" round.
here's an MP35N part. I just finished giving it a little heat to bring out some color.
