Pushing your Speedio
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 90
    Jul 2011
    Eugene, OR
    295
    107
    195
    Default Pushing your Speedio
    So with all the talk in the other thread about broken pull studs lets start a new discussion on hard are you pushing your Speedio/Robodrill (BT30).
    I have not broken a pull stud (Running High torque pull studs) but I am getting major Fretting. I have always noticed it since i bought the machine new.
    I was also talked out of Big plus which now i wish i bought it.
    The last job I was running a bunch of 1" thick 6061 plate and lost a endmill 3/4 of the way through the job. When I pulled the tool the holder was very fretted. Pioneer SX16 with a 3/8" Diamondback 1"LOC. Was doing 16Krpm, 1" deep., .100 stepover and 300ipm. Not a huge cut.
    I run a 2" Korloy ripper at 16k 1.9 stepover .125 deep at 175ipm and way less fretting on the holder.
    I run a 1/2" 1.5"LOC Diamondback at 1.5" deep .100 stepover and 250ipm.
    So now I'm thinking these cuts are way too much for Non Big plus spindle. Maybe even Big plus.
    How hard is everyone pushing and what do your holder look like standard or Big plus.
    Also looks like my spindle is trashed now.
    Attached Thumbnails Attached Thumbnails 20191119_091841.jpg   20191018_173814.jpg   20191119_100013.jpg   20191119_113727.jpg
    Nov 2005
    Illinois
    2,024
    210
    1568
    Sure dual contact would help. How much is hard to say. Have you condsidered going to a shorter gage length tool holder. That may do the trick. The holder you show isn't long by any means, but shorter are available and would only help.
  3. Likes DavidScott, Pete Deal liked this post
    Sep 2018
    Oregon
    400
    155
    143
    The only tool I've had show any fretting is my 2.5" face mill holder. I used it to machine some long steel slabs that turned out to have a lot of flex due to how they were bolted against a fixture. But the fretting is really minimal and only shows on the base of that holder. Spindle looks fine.
    I have a 10k RPM standard spindle. You're in Eugene? I'm up in Tigard, there's a few Brother owners local to the area.
    I run a 3/8"x1" Helical 35-deg rougher at 350ipm, 1" deep, .08" stepover, out of one of Frank's stubby holders.
    I run a 3/8"x1.25" Helical 35-deg rougher at 300ipm, 1.25" deep, .06" stepover out of a YG1 Hydraulic holder. That's a pretty long gage length and I've backed off of using that combination, but it didn't show any issues.
    I wouldn't run an SX16 holder for roughing but that's my preference. On the BT30 I really like the stubby endmill holders from Frank. I also use some Lyndex-Nikken EM holders that have a longer gage length.
    It looks like you might have had one tool start an issue in the spindle, then other tools that go into the spindle are being affected by damage to the spindle. The harm looks pretty minimal and I bet you could stone that damage out and run with it.
    Jul 2012
    Washington
    2,867
    1108
    1149
    That is some nasty fretting! I have learned that when you see fretting, PANIC!!! It will only get worse so stop whatever you are doing that is causing it. Yes, gage length will fix your problem. The best is the super stubby sidelock holders from MariTool, nothing compares. It took me 20 years to get over the idea that sidelocks are inferior to collets, but I am over it and use them quite a lot with no complaints. If I want a flat in the cutter I just whip out the air grinder with a 60 grit diamond pin in it and make one, takes about 20 seconds for a 1/4" cutter. Another big advantage to sidelocks is there is no big collet nut to keep the coolant from getting to the end mill.
    Oh, and if you are doing a finish cut with a different mill try a corncob rougher, way less cutting force than the psudo-rougher Diamond Backs.
  6. Likes Bobw, Pete Deal liked this post
  7. #5
    Jul 2012
    Washington
    2,867
    1108
    1149
    Quote Originally Posted by DethloffMfg View Post
    Yes, and the damage is missing metal, nothing to stone off. That spindle needs to be reground, worth sending to Setco vs local IMO.
  8. #6
    Jul 2016
    New Mexico
    587
    123
    154
    I don't really push my S700. The savings I could get pushing it harder aren't enough to justify the cost of spindle replacement.
    As an example with 7075:
    12 mm end mill, 3 flutes.
    6200 rpm
    3700 mmpm
    DOC: 29 mm
    Step Over: 0.6 mm
    For facing I'm using a 2" Korloy ripper also:
    6300 rpm
    5000 mmpm
    DOC: 0.6 - 0.8 mm.
    Standard BT30. No fritting marks.
  9. Likes Pete Deal liked this post
  10. #7
    Oct 2007
    SPAIN
    3,409
    1903
    1242
    That fretting would worry me to death...
    Try a GARR knuckle form cutter (ARC series) or a MA Ford series 134 which makes mince meat out the ally. It will lower your cut forces and could cure the fretting.
    I would rough at 10k RPM in one of Franks short and stubby sidelock. But it's only be running at around 220 Inches feed (5500mm/min) and this would be BBT spindle NOT plain taper...
  11. Likes DavidScott liked this post
  12. #8
    Jul 2012
    Washington
    2,867
    1108
    1149
    Interesting to note how much of the taper is supported in the spindle, looks just like my Enshu. I would be dealing with the spindle taper before buying any new tool holders, and once you do you need to toss the ones with fretting. Been there done that, and it is hard.
    I think for a 3/8" corncob MA Ford is the best, but I haven't tried Garr. For 1/4"-3/16" I really like Garr. Garr has an interesting tooth form, more like a threadmill than the rounded teeth of most corncob mills. I had a job where I was slotting .22" deep with a 3/16" Garr rougher 120 ipm at 6k. I could have gone much faster if I had more coolant pressure, I just couldn't clear the chips well enough.
  13. #9
    Jul 2011
    Eugene, OR
    295
    107
    195
    Yes
    Quote Originally Posted by DavidScott View Post
    I already run chip breakers in all my roughers, Destiny Diamondbacks. I have also ran Swiftcarb ramp mills.
  14. #10
    Jul 2012
    Washington
    2,867
    1108
    1149
    Destiny Diamondbacks and Swiftcarb ramp mills are rougher/finishers, not to be confused with a real rougher. Before I drank the Coolaid I used to use Diamondbacks for roughing, I still have a few new that I haven't touched in years, probably never will. Nearly all of my machining limitations are holding onto the part so corncob mills rule the roost for roughing in my shop. All BT30 spindles here too.
  15. #11
    Oct 2007
    SPAIN
    3,409
    1903
    1242
    My experience = MA Ford were great for 14mm & 12mm dia.
    The GARR are great for 12mm and below, because their 'knuckles" are finer.
    An 8mm dia MA Ford is all knuckle and just doesn't look that strong a cutter, purely because the knuckles are so big.
    Also, the MA Fords and GARRs would be run same speed and feed (and would show the same load on the control).
  16. Likes DavidScott liked this post
  17. #12
    Mar 2013
    Oregon
    1,815
    741
    2128
    I've heard you say that before... so I tried getting a decent wall finish out of the Diamondback, and it was a total no-go. How anyone could use that as a "finished" surface is totally beyond me.
    While I might agree it isn't a rougher in the classic sense, only a fucking butcher would call a final wall it has machined "finished."
    Fraisa has a new aluminum rougher they have developed. 30 degree helix, fully serated, coolant hole down the middle, extra strong core. They seem to have figured out a way to get the sheer action of a high helix mill (like the Diamondback) without the vertical pulling force that makes high helix stuff a bit risky to run.
    I have a set on order, I'll see what the pricing is when they arrive.
  18. Likes coffeetek, BROTHERFRANK liked this post
  19. #13
    Jul 2012
    Washington
    2,867
    1108
    1149
    Quote Originally Posted by gkoenig View Post
    They work if you tumble the parts enough, and don't mind some "witness" marks. Something you can make work when you have a 45 second chip to chip toolchange. Personally I don't have any use for rougher/finishers.
    Diamondbacks, and other rougher/finishers are a lot closer to a finish mill than a rougher. Corncob roughers not only cut with less side pressure they pull up much less. I was just looking at both the MA Ford and Garr sites, for a 3/8" corncob Ford says .01"-.035" per tooth and Garr was .001"-.0025", I know from experience Ford's are the one to follow.
  20. #14
    Jul 2006
    Hillsboro, New Hampshire
    7,521
    1771
    5236
    It's like the Garr copywriter didn't believe the engineer's suggestions, and added an extra "0" to the IPT values.
  21. #15
    Jul 2012
    Washington
    2,867
    1108
    1149
    And MA Fords copywritier figured roughers and finishers should feed the same.
  22. #16
    Sep 2007
    Washington
    5,177
    187
    1543
    To The OP's question ...
    I did get some moderate fretting ~1 year ago, on a steel job. Even though I was running fairly conservative feed & speed, everything got pretty hot and I got some fretting on the toolholder, which I tossed. That freaked me out at the time, but I figured I might as well just keep running and see how it goes. That was a year ago, and I have sent 1000's of parts through the machine since, many with high aesthetic and accuracy requirements, so whatever I did to the spindle has so far not manifested in any issues.
    Regards.
    Mike
  23. #17
    Jan 2013
    Gilbert, AZ
    5,876
    7403
    7466
    Quote Originally Posted by Bigtoy302 View Post
    I run almost those exact parameters with an SGS S-carb, in a 60mm gage SK16. (seriously, exact same speeds/feeds, stepover, DOC).
    Couple hundred parts/day for 10 months straight. No fretting. Tapers still look new (knock on wood).
  24. #18
    Feb 2005
    Akron, OH
    1,842
    283
    1384
    I have broken a pull stud, and don't have big plus spindles either, but I've never seen fretting like that on any of my machines, and I'll push them that hard.
    Are your pull studs torqued properly? If so, have you checked your drawbar tension? Any chance you got a counterfeit holder somehow?
  25. #19
    Jun 2015
    424
    87
    101
    I got some fretting when I was roughing in a ER32 collet (3/8 rougher 1.25" mostly) My local Yamazen apps eng. told me some is normal. I still use the toolholder on something lighter duty (maybe I should retire it). I switched to roughing in a Maritool sidelocks and the holders look perfect and they've been running for a good while. My holders don't all look perfect. After that pull stud thread, I've gone through and retorqued all my studs (and swapped a bunch out for high strength version) to a lower torque and a dab of loctite. I probably had them all overtorqued which I've read is not good.
  26. #20
    Apr 2014
    789
    1000
    532
    That part I bolded is a pretty big cut to me, for the cutter size, width of cut, depth of cut, and extension. I've not put it on HSM Advisor, as I don't have a copy on the confuser at home. Just my gut reaction says that.
    As others have noted, shorten the holder as much as possible and use a true rougher. Oh yeah, for sure only a sidelock.
    Good luck!
  27. Likes coffeetek liked this post
