jttest1423
- Apr 23, 2019
So I am installing a Ethernet-to-wifi adapter on a few of the machines here. This way we can connect them wireless and transfer files back and forth. I am using this adapter IOGEAR - GWU637 - Universal Wi-Fi N Transmitter- Ethernet to Wi-Fi N 300Mbps which takes the standard 5V DC from being USB powered and 500mA. I only seem to have 24Vdc sources in the cabinet. I would like to do a permanent install meaning I want everything to remain tidy in the cabinet so I looked into this:
https://www.amazon.com/DZS-Elec-Con...AKQM8VJKEJFZ&refRID=FRQWME5KAKQM8VJKEJFZ&th=1
Which would be perfect except that it outputs 3A. Will I still be okay with using this device or is there a better solution here?
Also side question but why does it seem like all the Okuma's I have worked with have -24Vdc power rails. Is there any way to get a +24Vdc terminal on the Okuma Machines, One being a very old MC-6VA and a very new 2SP-V920EX. To get around that I am currently planning on just buying a Din Rail Power Supply.
