exkenna
Stainless
- Nov 29, 2007
- North Alabama
Hey guys,
I could use a little help here.I have a local customer who has a job coming up that involves a good bit of turning and the material is beryllium copper. Yes, I am aware of the health concerns and safety precautions needed, no need to beat that dead horse.
Specifically: What edge prep and coating have you found that performs in this material?
It's smooth OD turning, no crust or interruption.
I need to order some test inserts so here are the 3 options I'm considering:
A) A stainless steel grade with sharp, positive edge prep and CVD coating
B) Steel grade with free cutting but tougher edge prep and black aluminum oxide coating.
This is a combination I've had good success with in medium carbon steels at high SFM's.
The Medium temperature CVD coating is polished and is super wear resistant.
C) A harder grade for Hi-Temp alloys with a positive, sharp edge and PVD coating.
(Doubtful this is correct for this material but thought I would list it as an option)
I'm leaning toward the Steel grade with the MT-CVD coating. Opinions from people who have turned this material?
Here's the steel grade with thick MT-CVD coating
ZCC CNG432-PM YBC252
