ProjectZero
- Oct 21, 2016
Hi guys,
Trying to get my reaming feeds and speeds right in aluminum...still relatively new to CNC. I'm used to using FSWizard and just trusting its numbers but for reaming I think I need to dig a little deeper and make sure I'm doing it right. I've tried reaming some holes before and they're bell like - definitely flared a bit in the beginning.
Right now I'm using a small 1/16th under reamer. .0624. I'm predrilling it using a .052 drill bit (#55). Now I usually trust FSWizard for flat end mill and twist drill feeds/speeds. For the predrill it tells me to use 10000 RPM (max of my machine) and 13 in/min feed rate. I've heard the rule of thumb is twice the feed and half the RPM. So for my .0624 reamer should I go 4500 RPM and 26 in/min feed rate? Does that sound about right?
Another question (more CAM) should I enter 26 in/min for both the Cutting Feedrate and the Plunge Feedrate?
I've emailed the manufacturer asking for recommended SFM for my .0624 reamer and am waiting to hear back. Thank you for your advice!
