Jay Fleming
Hot Rolled
- Aug 7, 2014
- Noble, OK
I think I'm about to the point of wanting/needing to actually purchase a true VMC. I've decided a 40x20 is the minimum and possibly the maximum I would get. My requirements are listed below. I've browsed Fadal, Haas, Bridgeport, Okuma, and I'm sure several others that are slipping my mind right now.
If there are other things I should consider as priorities, let me know.
Thanks in advance.
Jay
- X: 40" Y: 20" Z: 23"+
- CAT40
- Reliable or readily available parts
- 10 HP+
- 10,000 RPM
- 600 IPM rapids, 300 IPM cutting
- 20+ tool changer, side mount or carousel not an issue
- DNC or ethernet file transfer
- Conversational programming a plus
- Must fit through a 10'x10' door
- $20,000 max
Thanks in advance.
Jay
