Hi guys -
I'm looking for recommendations for a CNC machine that can be used to cut very small, very precise parts in plastic.
My typical parts would fit in a 50mm cube. They do have some tolerances down to +-0.05mm and walls < 1mm thick. The material is PC/ABS, ABS, PC/PET or similar. Geometrically, most of the features can be cut with a 1mm end mill, but some might require a smaller tool 0.5mm or even less.
Ideally I'd like to be able to do this both for easy prototyping of one-offs and for small scale production (10-100 parts/day). I think my designs are going to evolve quite a bit before I go to injection molding; 3D printed parts are trouble since they can't usually hit those tolerances and the mechanical properties just aren't the same.
I've done very little CNC milling work before (mostly whatever machines were at hackerspaces - wood or metal, no plastic) so I don't really know what I should be looking for here. A benchtop mill like a Taig or Sherline? Something like a CNC conversion of an X2? A small VMC eg Haas VF2? A mill specifically for micromachining eg Microlution, Datron etc?
What are the important specs? Which of these has the better positional accuracy / tolerance? What kind of tool and collet do I want? (and do I want an automatic tool changer?) etc.
Thanks for your advice! I hope this helps anyone else looking to make micro-machined parts out of soft materials.
Best regards,
Alex
Best regards,
Alex
