aarongough
Stainless
- Oct 27, 2014
- Toronto, Canada
Hey guys!
I'm slowly starting to look around for a small (used) turning center and I'm interested in recommendations...
All my parts would be made from a 1" bar or smaller, usually in the 1/4" or 3/8" diameter range. Part length will usually be under 1/2". Material will mainly be stainless, preferably pre-hardened like 17-4H900 or similar. Initially I don't forsee any need for live tooling but I wouldn't rule it out in the long term, definitely not a 'must have' as I'd be happy to just run that as a second op on my mill alongside other parts on my production fixtures.
All the parts made will be for use in my products so cycle time is not really a huge concern as I'm pretty sure any turning center will produce far more than I can use. I would like a bar feeder or bar puller though as running unattended is very important for me! I'll likely only be feeding short bars, 4' or 6' as it makes material storage/handling/delivery easier and my parts will all be very short so there won't be much wasted stock.
I'm happy to program in CAM or at the control as long as programming at the control is not a headache.
I would like to do maintenance myself so something simple with easily accessible parts/diagrams is a plus. 'The fadal of lathes' would be just fine with me
Current leads:
Miyano BNC34T: Looks like it could use some TLC, but overall I like the concept and size!
Okuma Cadet LNC8: The machine looked good but I'm not sure if the 8" hydraulic chuck is simply going to be too large for most of my work?
Okuma LB15: This one looks very nice, price is reasonable too, just not sure if it's going to run small parts well.
I'm thinking to also get a larger manual lathe for my one-off parts like automation components and so on, that way I don't have to break down the production setup on the turning center.
Thanks in advance for any advice!
-Aaron
Current leads:
-Aaron
