Casmer
- Oct 21, 2020
- Grant, FL USA
I have an older Fanuc 21M based CNC milling center. I have been getting it up and running for the first time. During this process I managed to get a memory parity error on boot. I had to use the 8+9 held on power to reset the parameters to boot up. Now that I have, if I go offset settings, I can't change the channel or punch settings (even though the parameter write is on). But I can edit them from the parameters menu.
Now, i tried to use the parameters screen to 'punch' out the parameters over serial, but the soft key doesn't move to the second list of options that has the PUNCH and READ options anymore.
I manually updated parameters 001 through 0140, but still nothing seems to be working. Does anyone know how to get the fanuc controls back up and running from this point?
