Hi guys I have some 1.75 OD, 1.5" ID aluminum tube that gets threaded on the outside. Parts vary in length up to about 12" long (threaded about 9"). I install a delrin plug in the end of the tube and support with tailstock.
Struggling a little with chatter right next to tailstock center. Which is strange as the middle looks fine and tailstock is nice and solid. Any suggestions on how to improve it? Something I can put inside the tube to dampen it? Needs to be very easy to install and remove.
I tried making a plug that extended well into the tube, and put bunch of o-rings on it. seemed to actually make it worse. Only thing I can figure is my longer plug was heavier and maybe changed the frequency it vibrated at and made it worse. What if I went to the extreme and make a very heavy plug, solid steel or something? Could this help?
What are some good ideas to dampen this tube? What kind of RPM would you expect to be able to run this setup at?
