MiamiCNC
- Dec 2, 2019
- Florida, USA
I bought my first CNC lathe, a 1995 Mazak QT20 which I have been slowly but surely rehabbing. I roughly leveled Z and removed the way twists in X. I've aligned the headstock so that it cuts within 2 tenth taper over 6". A facing cut leaves a small nub at the center, so I figure the turret needs to be clocked. It is square when indicating along the turret outer edge in Z. When I indicate in X I get approx 0.001 along the 3-4 inch holder slot. With a 1" drill rod placed in a new block, I indicate about +/- 0.004 up/down, with the bar being too low. I am trying the reclock the turret and would like some pointers. I loosened the 8 bolts on the face of the turret which I assume attach the turret to the curvic (circled in green on the attached pic). Placed a 1 inch square, 3 foot long bar in a holder and pushed liked hell, but no movement. So I figure that the turret may have taper pins attached. I am now trying to remove the turret by loosening the compression nut on the center shaft and prying the edges and also hitting with a dead blow hammer. The sucker won't budge. This is the first time I've ever tried to do this, so I figured I's ask for advise before breaking anything. I have several questions:
Thanks in advance,
Dan
- The rusted ring with several bolts around the center nut I assume is a spline hub and does not be removed. It should come along with the turret, right?
- Do I need to remove the 8 bolts holding the turret to the curvic? I assume not
- Any tricks to unseating the turret? Do I need to build a flywheel puller?
- What is the purpose of the two large set screws on the face of the turret (circled in red on my pic).
Thanks in advance,
Dan
