Removing very minor surface rust from steel parts
Results 1 to 14 of 14
    Sep 2006
    Atlanta, GA
    3,054
    445
    947
    Default Removing very minor surface rust from steel parts
    Have ~500 steel parts that have been in our storage shed for several years that have a very minor amount of surface rust that needs to to cleaned before they can be sent out. I would prefer to use a liquid in a 5 gal bucket as they have threaded areas that would make it difficult to do by hand.
    Hope to find a mild acid of some sort that wouldn't require a chem suit and SCUBA gear to use and time in bucket isn't a big deal just need to be clean.
    What would you recommend?
    Jan 2007
    Norfolk, UK
    18,484
    14012
    14003
    This is my go to in the UK Captdave so you must have something similar
    deb Janitol(R) Altrans(R) rust or limescale remover for idustrial use
    Sep 2006
    Atlanta, GA
    3,054
    445
    947
    Thanks Limiy,
    I'll see if there is a US supplier.
    Dec 2004
    uk
    14,057
    4552
    6698
    IME acids can leave stain marks, a quick tumble in a vibratory polisher with something as soft as kiln dried paving sands worked well for me before.
    Feb 2018
    Washington
    7
    20
    I've used WD-40 and stainless steel wool to pretty good effect. Now that I think about it Kroil has worked really well for that too.
    Nov 2008
    Madera county california usa
    2,386
    21
    590
    Get a bucket and fill it with paint thinner and let parts soak a day or so.
    May need a wire brush depending on shapes.
    Paint thinner is really thin oil so it will have an oil film.
    Sent from my SAMSUNG-SGH-I337Z using Tapatalk
    Jul 2002
    Maryland
    4,396
    721
    590
    What about Evap-o-Rust in a bucket? Beware, my experience is it can slightly darken higher carbon steels. So do a test piece first.
  8. Likes ernieflash liked this post
  9. #8
    Apr 2009
    Ohio
    193
    17
    60
    Plain old muriatic acid from the hardware store diluted with water will work perfectly. Rinse vert thoroughly and then dip into a water displacing rust preventative. We like Prism Lubricants's RP-4 much cheaper and longer lasting than WD-40. RP-4 leaves a very thin waxy film on the parts for up to one year in storage.
    DO THIS IN A WELL VENTILATED AREA PREFERABLY OUT OF DOORS. WEAR PROPER PPE ETC.
  10. #9
    Mar 2009
    4,866
    89
    899
    I would suggest something like The Must For Rust or something equivalent product for lime and scale removal. But those tend to darken surfaces. And since you have threaded parts that would mean a lot of cleaning. Instead go to the supermarket and get a couple of gallons of vinegar (about $1/gal). Use some agitation with a stick every hour or so. Process will take a few hours because the solution is not that strong.
  11. Likes SWYooper liked this post
  12. #10
    Feb 2018
    29
    16
    27
    Quote Originally Posted by rons View Post
    Plain white vinegar is a cleaning agent far too few people seem know about. I always have a couple gallons on hand at home.
  13. #11
    Oct 2005
    14,303
    Quote Originally Posted by Limy Sami View Post
    Maybe the product called "C.L.R." ?
  14. #12
    Mar 2003
    283
    16
    24
    Warm Citric Acid solution. Check the internet for ratio but I think it is 1 cup +/- per gallon of warmish water.
  15. #13
    Sep 2006
    Atlanta, GA
    3,054
    445
    947
    We had a gallon of this aluminum brightener from NAPA that has been on the shelf for years so thought I would at least give it a try.
    After 1 hour in the bucket the parts come out amazingly clean and free of any rust staining, rinse in clear water and immediately dip in Rustlick B and good to go!
    Haven't looked on the net to see what in it but very low odor.
  16. #14
    Feb 2008
    Ohio
    11
    Another vote for Evap-O-Rust. I use it for rust removal for old car parts. Amazing performance for my purposes, but it may not give you the appearance you are looking for for your parts, would just have to try it an see.
