Stephan Spears
- Apr 12, 2014
- AB,Canada
Hello,
Maybe this is a bit off topic. But has anyone encountered a situation where the renishaw High-precision motorised arm (HPMA) won't come down upon the execution of the M code?
I have a HPMA installed on my lathe. I tried to use the arm to measure a tool today but after I entered the M code, the arm went down only half way and stopped. I run the other M code, trying to let the machine bring the HPMA back to its "home" position. It wouldn't work. I tried a couple more times and it wouldn't work either.
I contacted the machine builder and basically, they didn't have the solution.
Then oddly enough, just after I finished the call with the machine builder, I run the M code again to bring back the arm and it worked...
I am so confused now! LOL
