Renishaw probe tip, ceramic or steel?
Results 1 to 12 of 12
    Mar 2015
    Oregon
    14
    Default Renishaw probe tip, ceramic or steel?
    HAAS VF2. I use my Renishaw probe every day, every job, would not want to be without it.
    About once a year, I send the probe in an unexpected direction, and break off the tip
    I have been using ceramic tips, they snap right off.
    I see that the stainless shaft styli are less money. Anyone have experience with these?
    If it crashes into the work, will it bend, or will it cause damage the probe head?
    I'm thinking of buying several replacements, probably should stick with ceramic?
    Aug 2006
    Wisconsin
    1,513
    645
    572
    Honestly, if you cash it that much, I would stick with ceramic, that is what it is for, to break. My probe is carbide shank, but tiny, about 2mm dia. I think ceramic is better to keep the heat out of it as well..
    Jan 2013
    Plainfield, Indiana, USA
    1,580
    1163
    828
    The stainless tube is much harder to break / bend than the ceramic. Much better to stick with the safer ceramic. The cost of a probe body is much more than you could save with the price difference.
    Feb 2013
    Madison, WI
    727
    926
    467
    Like Red and Fidia said. Stick with the ceramic. The probe body is going to cost over $3k w/out a core and over $1500 with core.
    Sep 2013
    Minnesota
    175
    24
    32
    If you are crashing probes, it sounds like you are not using a cad/cam or a 3rd party software such as Renish Productivity+ to create your probing programs. With software you will have the same peace of mind as you would when programming collision free toolpaths. Even if you don't use CAM software you can still get a stand alone probe software. I totally recommend it if you have room in your budget because probe heads are delicate and expensive so you don't want to abuse them at all.
    If your Haas has the Renishaw macros and you are creating your probe programs by hand, you can use protected moves to position the probe. I think the macro is 9810; I hope this helps...
    Dec 2008
    New York
    8,691
    2312
    Quote Originally Posted by Qwan View Post
    99.999% of time i crash probe its cause i put a part in a vise backwards. no money cad cam etc is going to prevent a mistake.
    you never put part in backwards ? its like breaking taps the more holes you tap the higher the chance you will break a tap eventually
  7. Likes PROBE liked this post
    Jul 2011
    Navasota / Whitehall Texas
    3,435
    2523
    1867
    I have an older Renishaw MP 11 probe with a set of steel tips. They will not break if crashed. To prevent damage to the probe Renshaw sells a special linkage that attatched to the probe body then the metal tip is screwed to. That link is designed to break if the probe is crashed...
    I would just stick with what you have ...
    Sent from my SM-N900V using Tapatalk
  9. Likes mhajicek, tteitgen liked this post
  10. #8
    Nov 2005
    1,509
    13
    159
    I used to run the fuse links on 150mm ceramic probes, saved a lot of broken stili over the years, they can have a small effect on trigger accuracy, but nothing that most of us or our machines would notice.
  11. #9
    Mar 2013
    Oregon
    1,329
    593
    1456
  12. Likes mkd, Tonytn36, adama, ranchak liked this post
  13. #10
    Mar 2015
    Oregon
    14
    Thanks guys,
    That's what I expected to hear, stick with the ceramic, it's a safe choice.
    Compared to the price of the head, it's better to be safe than to repair the head unit.
    This is my third broken one in the first two years of owning this mill, and the first two were in the first 6 months, so I think I am getting better. With one off parts, and constant setups, there is always a way to break something. LN
  14. #11
    Mar 2017
    294
    113
    31
    Breaking the pro-tip happens, we are only human! I actually saved a bunch of probe stylists, the ceramic ones by Super glowing a .120 something pin in between the 2 broken pieces. That actually lengthened the stylist for parts with those deep, hard to get at places as well saving a bunch of money over the years and the good thing is if I messed up and crashed it it would break just like it would be for just at a different spot and typically after that it was unrepairable haha but in a pinch if you only have one and you have two separate pieces now you can simply superglue a pin in between the two back together. That got me out of a couple of jams until the new one came in.
    Sent from my SAMSUNG-SM-G891A using Tapatalk
  15. #12
    Sep 2014
    1,502
    940
    1064
    You can order replacements direct from Q-Mark. Q-Mark Probe Styli - Order Online
