swinthrope
- Jan 6, 2017
I am trying to understand how the Renishaw macros deal with work offsets.
Generally, I would like to understand how the macros such as G65 P9810 deal with work offsets and if there is a way to alter their default behavior. They appear to operate in their own pseudo offset plane where X0,Y0,Z0 are the position of the spindle when the macros are run. I would like to find a way to get them to work from some offset - G53, G54, etc.
Specifically I would like to jog the machine over a fixture, probe G54 Z off of a fixture, then do a protected move up to 1.25" off of the newly found Z0.
Something like this:
G65 P9832
G65 P9811 Z-.5 S1.
(Maybe Something here to get make the protected move in G54)
G65 P9810 Z1.25 F150.
I am also open to any other options to end up with the same result, but whatever solution must provide a Z at a very specific height relative to the fixture for further probing moves otherwise I will miss surfaces.
If it matters this is a Haas NGC with WIPS.
Thank you!
G65 P9832
G65 P9811 Z-.5 S1.
Thank you!
