Replacing Dynapath Delta 20 spindle control with VFD
Likes Likes:  0
Results 1 to 1 of 1
    Aug 2019
    Wisconsin
    5
    Default Replacing Dynapath Delta 20 spindle control with VFD
    Hi,
    I need to add a VFD to run the 3 phase spindle motor on my Clausing Kondia FV-1 that has a Dynapath Delta 20 installed. According to the schematic pdf, and by inspection, it looks like I can just run 220V single phase to the two step down transformers to run the rest of the controller. Can I just detach the three wires from the fuses that go to M1 for the spindle control, or will the controller fault do to no power being present on that circuit?
    Page two on this pdf: http://www.dynapath.com/us/data/file...ingDiagram.pdf
    Thanks for any advice.
    Jeff
