Hi,
I just got a Clausing Kondia VF-1 which has a Dynapath Delta 20 installed. The Delta 20 is currently in charge of turning the spindle on and off and controlling the direction. I need to use a VFD for the 3 phase motor so I'd like to feed only 220V single phase to the Delta 20 for the rest of the electronics, and handle the spindle control with the VFD. Does anyone know if I just remove the 3 wires that go from the fuses to the M1 terminal block for the spindle, if the Delta 20 will throw any errors since the spindle stuff won't be receiving any power?
Jeff
Jeff
