706jim
Titanium
- Jun 14, 2006
- Thunder Bay Canada
OKK machining center with Fanuc 6MB. Moved from one building to another and have developed problems. Machine worked ok for a short time and then stopped in the ATC cycle with a spindle orientation alarm. Cleared this, but it's as if the machine is stuck in the middle of the sequence. It is possible to index the carousel manually and the control is still keeping track of the assigned tool numbers. However I can't call tools using MDI and some other odd things are happening as well. Notably the fact that the control off switch will take the machine out of "ready" but won't turn off the CRT, behavior I haven't previously noticed.
In short, is there some way I can get the tool changer cycle back in synchronization?
