I'm pretty much self taught at programming and I've managed to get by so far but I'm a little stumped on this one.
I have a program I wrote where I use a counter on a couple variables. For the program to continue on, I need the value to be what I declared at the beginning. So far I just rewrite the variable's value after the operation. However, if I want to change that variables value, I have to change it in numerous spots in the program. The purpose of this is because I wrote the program to be selectable for a series of parts that are all relatively identical but have slight variances in dimensions. Then all the operator has to do is change #100. Is there an easier way to do this? This is still a rough draft but variables #105 and #106 is what I'm getting at. Thanks.
Fanuc 31 controller.
Code:
(#100=1)(310004)
(#100=2)(310005)
(#100=3)(310006)
(#100=4)(310007)
#100=1
IF[#100NE1]GOTO0200
N0100
#101=13.4(Y0 TOP)
#102=3.6 (Y0 BOTTOM)
#103=320. (B AXIS)
#104=.9 (WALL)
[B](1)#105=4.4 (HEIGHT)(5 PLACES)
(1)#106=2.8 (WIDTH)(5 PLACES)[/B]
#107=0.05 (DOC)
#108=1.5 (TOOL DIAM)
#109=0.25 (RADIUS)
GOTO1000
N0200
IF[#100NE2]GOTO0300
#101=15(Y0 TOP)
#102=2 (Y0 BOTTOM)
#103=320. (B AXIS)
#104=.9 (WALL)
#107=0.1 (DOC)
#109=0.5 (RADIUS)
GOTO1000
N0300
IF[#100NE3]GOTO0400
#101=10(Y0 TOP)
#102=5 (Y0 BOTTOM)
#103=320. (B AXIS)
#104=.9 (WALL)
#107=0.01 (DOC)
#108=1 (TOOL DIAM)
#109=0.25 (RADIUS)
GOTO1000
N0400
IF[#100NE4]GOTO1000
#101=13.4(Y0 TOP)
#103=320. (B AXIS)
#104=.9 (WALL)
#107=0.05 (DOC)
#109=0.25 (RADIUS)
GOTO1000
T99M6
N1000
G91G28Z0
G0G17G90G94G54.1P5X0Y[#101-[[#105/2]+[#108/2]]-.1]S1530M3B[#103]
G43Z12.1H99
G1Z7.8F10
M50
G1X0Y[#101-[[#105/2]+[#108/2]]]F10.
WHILE[#106GT#104]DO1
G91G17
G1X-[[#106/2]+[#108/2]]F70.1
G2X-#109Y#109I0J#109
G1Y[#105-#107+[#108/2]]
G2X#109Y#109I#109J0
G1X[#106+[[#108/2]*2]]
G2X#109Y-#109I0J-#109
G1Y-[#105-#107+[#108/2]]
G2X-#109Y-#109I-#109J0
G1Y[#107]
#105=#105-[#107*2]
#106=#106-[#107*2]
END1
[B](2)#105=4.4
(2)#106=2.8[/B]
G90G0Z10.
IF[#103EQ40]GOTO1100
X-[[#106/2]+[#108/2]+.1]Y[[#101]-[#105/2]-[#108/2]]
Z5.
G1
X-[[#106/2]+[#108/2]]Y[[#101]-[#105/2]-[#108/2]+[#104/2]]F10.
WHILE[#106GT0]DO1
G91
G2I#109J0F70.1
G1X#107
#106=#106-#107
END1
Y-#109
WHILE[#105GT0]DO1
G91
G2I#109J0F70.1
G1Y#107
#105=#105-#107
END1
[B](3)#105=4.4
(3)#106=2.8[/B]
N1100
IF[#103NE40]GOTO1999
X[[#106/2]+[#108/2]+.1]Y[[#101]-[#105/2]-[#108/2]]
Z5.
G1
X[[#106/2]+[#108/2]]Y[[#101]-[#105/2]-[#108/2]+[#104/2]]F10.
WHILE[#106GT0]DO1
G91
G2I#109J0F70.1
G1X-#107
#106=#106-#107
END1
Y-#109
WHILE[#105GT0]DO1
G91
G2I#109J0F70.1
G1Y#107
#105=#105-#107
END1
[B](4)#105=4.4
(4)#106=2.8[/B]
N1999
G90
G0G80Z17.
G91G28Z0
N2000
G91G28Z0
G0G17G90G94G54.1P5X0Y[#102+[[#105/2]+[#108/2]]-.1]S1530M3B[#103]
G43Z12.1H99
G1Z7.8F10
M50
G1X0Y[#102+[[#105/2]+[#108/2]]]F10.
G91G17
G1X[[#106/2]+[#108/2]]F70.1
G1X-[#106+[#108/2]*2]
G2X#109Y#109I#109J0
G1Y-[#107]
#105=#105-[#107*2]
#106=#106-[#107*2]
END1
[B](5)#105=4.4
(5)#106=2.8[/B]
G90G0Z10.
IF[#103EQ40]GOTO2100
X-[[#106/2]+[#108/2]+.1]Y[[#102]+[#105/2]+[#108/2]]
Z5.
G1
X-[[#106/2]+[#108/2]]Y[[#102]+[#105/2]+[#108/2]-[#104/2]]F10.
WHILE[#106GT0]DO1
G91
G2I#109J0F70.1
G1X#107
#106=#106-#107
END1
Y#109
WHILE[#105GT0]DO1
G91
G2I#109J0F70.1
G1Y-#107
#105=#105-#107
END1
[B](6)#105=4.4
(6)#106=2.8[/B]
N2100
IF[#103NE40]GOTO2999
X[[#106/2]+[#108/2]+.1]Y[[#102]+[#105/2]+[#108/2]]
Z5.
G1
X[[#106/2]+[#108/2]]Y[[#102]+[#105/2]+[#108/2]-[#104/2]]F10.
WHILE[#106GT0]DO1
G91
G2I#109J0F70.1
G1X-#107
#106=#106-#107
END1
Y#109
WHILE[#105GT0]DO1
G91
G2I#109J0F70.1
G1Y-#107
#105=#105-#107
END1
[B](7)#105=4.4
(7)#106=2.8[/B]
N2999
G90
G0G80Z17.
G91G28Z0
IF[#103EQ40]GOTO9999
#103=40.
GOTO1000
N9999
G0G80Z17.
G91G28Z0
M1
G0G91G28Y0B0M5
M20
M60
M30
