mclausen
- Jan 13, 2014
- United States
I have a Kitamura MyCenter 1 with a Fanuc O-MC control that I want to add a 4th axis to. I have a Yukiwa SNC 4th axis that I will be changing the motor to a O-1SP/3000 with a C serial encoder. The 4th originally cam with an absolute encoder, so all it has is a home switch. There is no decelerate switch or limit switches.
Is there a way to home the axis without a DEC4 switch? I don't mind manually jogging it close, and letting it search slowly for the home.
Also, since there is no limit switches, do I just leave the -4 and +4 pins disconnected?
I noticed there is a 4NG input listed for the I/O card. I assume this is a 4th axis neglect. Is it possible to add a switch to this input to neglect the 4th when it is not on the machine without having to go in and change the parameter?
Finally the brake actuation pneumatic valve in this 4th has position switches to notify the valve position. Is there a way to tie these back to the M10 and M11 codes that operate the brake so there is a finished signal before the next move is processed? I don't see any I/O inputs listed for these signals.
Mike
Mike
