Retrofitting a spindle chiller onto a Fadal VMC15 - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #21
    Jan 2019
    Missouri
    129
    34
    20
    https://ebay.us/TMaHxQ
    $240 and 300% less mickey mouse
  2. #22
    Feb 2005
    9,050
    13928
    10722
    Quote Originally Posted by GENERALDISARRAY View Post
    That makes sense.. Chiller off a Japanese machine. Most likely running velocite.
    Probably has a pump in it with the life expectancy of Betty White, not a Soda
    fountain pump.
    The only thing that scares me on that one.. "Works GREAT".. Sold AS-IS.. No returns,
    and you have to arrange the shipping, which is a pain in the ass... And then that
    customs BS to get it into Canada..
    Complete opposite of a Fadal.. The machine is dead and gone, but the chiller still works...
  3. #23
    Oct 2006
    Klamath Falls, Oregon
    3,640
    418
    1008
    Aaron, this is what I have, I feed into the lower port and out the upper port.
  4. Likes Bobw, aarongough, Mstcnc liked this post
  5. #24
    Jan 2003
    354
    47
    94
    https://www.amazon.ca/Chiller-Daddy-...9363854&sr=8-6
    Id be tempted to try this. Same idea as what fadal used. Nice and compact. Brand new and free shipping to Canada for a good price. Fadals cooler was 1/5th hp, this says 140 watts, not too far off if specs are accurate.
    You need to have a temperature difference for a radiator to work, it wont do anything until the spindle has already warmed up and shifted Z height. Its better for keeping warm things like engines and tig torches from getting way too hot. If you want to maintain ambient temperature, and Z height, you will be better off with a proper refrigeration unit.
    The Daiken unit looks good too. A little bulky, and its 3 phase. The original fadal system is designed to use 120v single phase if your planning on using original controls.
  6. #25
    Oct 2006
    3,640
    418
    1008
    My solution is a period correct replacement for the "Prestone can" cooler it would have had from the factory. I don't have chilled screws, so only the spindle heat is being transferred to the cooler assembly. A couple degrees above ambient would be a stellar result. If I want a chiller, I could just put my tank inside a mini-fridge.
    The purpose of the chiller is to remove the heat put into the system by friction, if the chiller cools below ambient, then you have an opposite situation that the screws shrink and spindle bearings won't be at proper clearance.
    Remember, bearings are assembled so that they reach running clearances at operating temperature.
  7. #26
    Oct 2009
    Oregon
    4,340
    4661
    2240
    The oil is just a better all around solution. All my mills have oil chilled spindles and one has the spindle motor on it's own cooler circuit too. It just works and there's no nasty mess or surprises when you have to work on something.
  8. Likes DavidScott liked this post
  9. #27
    Oct 2014
    CANADA
    Ontario
    1,213
    689
    929
    Quote Originally Posted by Perry Harrington View Post
    Perry! Thanks for posting that mate! I found some photos of 'cool power' fadals yesterday which showed plumbing going into the same spot on the spindle, so between your picture and the stuff online I'm fairly confident that port is supposed to be used for coolant Thanks again!
  10. #28
    Oct 2014
    CANADA
    Ontario
    1,213
    689
    929
    For future reference for myself, and for anyone else thinking about retrofitting a spindle cooler onto a Fadal, here are some useful part numbers:
    The o-ring that goes around the lower end of the spindle before it's fitted into the casting is McMaster part no: 9452K321 (McMaster-Carr)
    The o-rings for sealing the top end of the spindle are:
    Small - McMaster part num: 9452K23 (McMaster-Carr)
    Large - McMaster part num: 9452K195 (McMaster-Carr)
    The fitting I'm using for the spindle nose inlet is a 90º elbow with 1/4" NPT on one leg and 1/2" push to connect on the other: McMaster-Carr
    The coolant outlet on the top is only 1/8" NPT but I want to get back up to 1/2" pipe as quickly as possible to reduce flow constriction. To do that and to fit into the available space I'm using:
    1x 90º 1/4" to 1/8" reducer: McMaster-Carr
    1x 1/4" NPT to 1/2" push to connect: https://www.mcmaster.com/51495K195
    The fittings seem to be really high quality, nicest looking PTC fittings I've seen yet! I bought 25' of 1/2" polyethylene tube for the plumbing but I think it might be a tad on the stiff side to run through the cable chain, I will try it and report back.
  11. Likes metal-ica liked this post
  12. #29
    Oct 2006
    3,640
    418
    1008
    That poly tubing might kink inside the cable chain, the rubber hose has a rather thick wall and doesn't kink. That's the main problem I've had with plastic tubing, except for air-brake tubing (unless you bend it too far and kink it).
  13. Likes aarongough liked this post
  14. #30
    Feb 2005
    9,050
    13928
    10722
    Quote Originally Posted by aarongough View Post
    Ok.. So now what is the rest of the plan??
    I'm voting for an Oompa Loompa sitting on top of the spindle pouring velocite down a
    funnel out of a powder horn.. That would make a great video.
    I'm joking of course, though that would make a good video..
  15. Likes mmurray70 liked this post
  16. #31
    Feb 2014
    Sunny South West Florida, USA
    2,893
    10715
    3288
    Quote Originally Posted by Bobw View Post
    I'm 5'3... I'd volunteer to do that for a video.
  17. Likes Bobw liked this post
  18. #32
    Oct 2006
    3,640
    418
    1008
    I just had this vision of someone riding a Fadal spindle head like one of those mechanical bulls in a bar.
  19. Likes Bobw liked this post
  20. #33
    Feb 2014
    2,893
    10715
    3288
    I'm trying really hard to find the picture from the Machinist facebook group of a guy riding the head of a BIG mill turn like a bronco. It's hilarious.
  21. #34
    Oct 2006
    3,640
    418
    1008
    Quote Originally Posted by TeachMePlease View Post
    Was he a Darwin award winner?
  22. #35
    Feb 2014
    2,893
    10715
    3288
    Nah, it was stationary, just a photo op, not an award ceremony
  23. #36
    Sep 2010
    Oklahoma City, OK
    4,484
    774
    1851
    SO what stops someone from changing the pump's soft parts to another material and then putting in some spindle oil as the coolant?
  24. #37
    Oct 2006
    3,640
    418
    1008
    Quote Originally Posted by Cole2534 View Post
    I used a coolant pump, so nothing stops me
