Rigid taping rpm - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 49 of 49
  1. #41
    Aug 2015
    CANADA
    Ontario
    6
    wow Bob you lost me
  2. Likes CarbideBob liked this post
  3. #42
    Jan 2017
    Oregon
    2,783
    493
    1979
    Quote Originally Posted by CNCbeginer View Post
    Thanks Jancollc,
    I should have mentioned that i am using a floating tap holder, My speed is at 250rpm
    If i change my speed will the program still be ok?
    I assumed you had a floating holder by your feedrates. Yes, you can change the RPM in the program.
    The tension/extension holders vary. Some release, some don't. Releasing holders are designed that way to control the depth- not a factor on your thru holes.
    It's not uncommon to program a slightly higher or lower feedrate going in, depending on how long your spindle takes to reverse. I have never seen someone program a lower feedrate both going in and coming back out- this would mean the holder is extending both directions, and you risk busting the tap or tearing out the threads.
    I start with my tap pitch going in and coming out, and I watch the holder to make sure I am not getting to the travel limit of the holder. If I am extending too much on the way in, I'll increase the feed a bit, etc. I like to see a little bit of compression on the way in, and extension at the spindle reverse and feed out.
    Watch your RPM increases, as this will affect the time it takes the chuck to stop and reverse. That in turn will affect how much travel you are using on the holder.
  4. Likes CNCbeginer liked this post
  5. #43
    Aug 2002
    West Unity, Ohio
    25,561
    5811
    8177
    I typically feed in slightly under - with a hard start.
    If my holder doesn't have a hard start, it will by the time I walk away.
    Compression is a very big cause of junk parts!
    Feed in slightly under rate, and maybe feed back out at rate, or even slightly under - depending on reversal time.
    Main spindle on a lathe - prolly want to feed under.
    Sub-spindle or GT27 type machine - prolly feed at rate.
    If you are under feeding on the way in - you already have some cush, and then when you hit that Z+/G4 line, you will get some more yet.
    Over feed on the way out and you will be trying to pull the first thread on the way out.
    Think Snow Eh!
    Ox
  6. Likes CNCbeginer liked this post
  7. #44
    Aug 2015
    CANADA
    Ontario
    6
    Quote Originally Posted by jancollc View Post
    Thank You for the explanation, I have a better understanding of what i'm doing now
    Thank you for thatI'll adjust the feed a bit to get it close to .050
  8. #45
    Jan 2007
    Flushing/Flint, Michigan
    8,143
    416
    6718
    Thanks Jancollc,
    With a floating tap holder you push the advance per rev higher than than the thread on purpose.
    You want to "push" it but not run out of travel in the float or spring.
    It will not start like a rigid so it will lag
    You do not want to hit solid on the bottom but well in on compression is good.
    If you program at rigid tap feed likely it will not work well.
    In such you want to use some of the spring built in and it should for sure compress during the process.
    Bob
  9. #46
    Jan 2014
    Washington
    4,729
    857
    2565
    ..I should have mentioned that i am using a floating tap holder, ....
    Since you are using a floating holder, why post in a thread about rigid tapping????
    Your code doesn't look like any rigid tap code I have seen either.
    Maybe start a new thread?
  10. #47
    Jul 2013
    Indiana
    3,244
    4759
    1638
    I modify the spindle speed to an even feedrate or at most 1 decimal out and modify spindle speed.
    We work in base 10, computers work in base 2, some numbers on the right of the decimal point don't convert well between the two worlds. That is confusing.
    Internally it is likely your control is doing all the math in encoder counts so rounding and if you have inch or metric screws comes into play on that conversion.
    In most use you only are off by one or two counts and no servo is that accurate so it is never a seen problem. There are some numbers worse than others.
    0.1 + 0.2 does not equal 0.3 in a computer.
    https://0.30000000000000004.com/
    Fanuc used to do BCD math inside which is somewhat different, I do not know if the new ones still do.
    Encoder count rounding, servo lag and tracking kill most of this by miles.
    Anywho, the error is small and your spindle and axis can't track within it anyways so those extra decimals on your feed make you feel good but are not going to happen
    A 20 inch long or deep thread and then the errors may stack up to some oh-shit.
    A metric screw machine tool at one micron resolution has a problem with .0001 inch moves. There is a skip or jump and no way around it.
    How close is the spindle speed to real and how tight the loop to the feed axis. Rigid tap usually ties one to the other in a master/slave on the numbers you supplied.
    Resolution on the spindle may matter.
    I just like staying out of decimal points as I know any control can handle that so I just move the RPM this or that ways.
    Bob
    Bob I've never seen anyone explain it like this. If I understand it correctly then you've convinced me. Have you noticed any improvements doing it this way? Longer tap life, better threads? Weather you have or you haven't I can't see it hurting anything going this route. Time be the only thing. If you rounded down on the RPM that is.
    Brent
  11. #48
    Nov 2014
    Florida
    4,087
    1617
    1904
    All I can say is I'm glad I haven't needed to use a floating tap holder in forever!
  12. #49
    Sep 2002
    Lawrenceville GA USA
    6,271
    848
    1370
    Kind of neat seeing a thread of mine that I started 10 years ago. First CNC mill that I worked on that supported rigid tapping. Still using some of the advice given here today.
    Charles
