Rigid Tapping - Breaking Taps on Tormach
Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    Jan 2020
    New York
    9
    Default Rigid Tapping - Breaking Taps on Tormach
    Hi Guys,
    New machine owner, need some help. I keep breaking taps on my Tormach. It has rigid tapping and i'm using an ER20 tap collet, standard ER collet.
    M2.5 X 0.45 Tap size.
    6061 Aluminum
    Fusion 360
    Tormach
    Do I need a dedicated tool? I thought I could just use a standard ER Collet holder if I had rigid tapping.
    Jun 2018
    Idaho
    127
    28
    29
    Post your code and maybe someone can help you. What taps are you using? What size is your hole before tapping? Bottom hole or thru hole. We need more details.
    Jan 2020
    New York
    9
    Thanks VTM,
    Through hole tap, my drill size is a #45 drill / 0.820" / using a YMW spiral bottoming tap. I can't even hit bottom of the part before the tap breaks. I'm using a ER tap collet with just an ER holder. My machine has rigid tapping.
    Here's my code:
    G90 G54 G64 G50 G17 G40 G80 G94 G91.1 G49
    G20 (Inch)
    G30
    N10(M2.5x.45 tap)
    T25 G43 H25 M6
    S250 M3 M8
    G54
    G0 X1.8 Y0.6705
    G0 Z0.38
    G0 Z0.28
    S250
    G98 G84 X1.8 Y0.6705 Z-0.65 R0.28 F4.4
    X1.998 Y0.4295
    X2.802
    X3. Y0.6705
    X3.198 Y0.4295
    X4.002
    X4.2 Y0.6705
    X4.398 Y0.4295
    X5.202
    X5.4 Y0.6705
    X5.598 Y0.4295
    G80
    G0 Z0.38
    M5 M9
    Jan 2007
    New Jersey
    995
    506
    498
    Quote Originally Posted by nyjiki View Post
    Thanks VTM,
    Here's my code:
    G20 (Inch)
    G30
    N10(M2.5x.45 tap)
    T25 G43 H25 M6
    S250 M3 M8
    G54
    G0 X1.8 Y0.6705
    G0 Z0.38
    G0 Z0.28
    S250
    X1.998 Y0.4295
    X2.802
    X3. Y0.6705
    X3.198 Y0.4295
    X4.002
    X4.2 Y0.6705
    X4.398 Y0.4295
    X5.202
    X5.4 Y0.6705
    X5.598 Y0.4295
    G80
    G0 Z0.38
    M5 M9
    Your original post said 4-40 tap but your program says 2.5 X .45, which is it? But, to your point, if it is 4-40, you are using a way undersize drill if you are using a .082" drill. My tap chart calls for .089 (#43) drill. 4-40's are hard enough, don't make it any harder.
    Mar 2013
    NW Pa
    396
    57
    167
    I didnt do the math but it looks like you programmed the wrong tap
    N10(M2.5x.45 tap)
    Sep 2015
    Ohio
    1,218
    790
    1221
    That’s awful deep for that size tap. I’d switch to a roll tap
  7. Likes TDegenhart liked this post
    Jan 2007
    New Jersey
    995
    506
    498
    In addition to using the wrong drill, your feed is wrong. If you are going to use 250RPM, then your feed should be F6.25. 250RPM X .025 pitch=6.25 feedrate.
    Is the program you posted the actual program you are using? Because it is programmed for a 2.5MM X .45.
    Paul
  9. #8
    Jul 2010
    corvallis,or
    877
    90
    369
    Haven't looked at your code but why are you using a bottoming tap on a through hole? Spiral point gun tap will reduce cutting forces. Also might want to consider form tapping it.
    Teryk
    Sent from my XT1710-02 using Tapatalk
  10. Likes TDegenhart liked this post
  11. #9
    Jan 2020
    New York
    9
    Sorry meant M2.5X0.45 tap
  12. #10
    Jan 2020
    New York
    9
    I was thinking roll forming it as well. The bottoming tap was what we had, didn't think about the cutting forces. Thanks for the input
  13. #11
    Jan 2020
    New York
    9
    Yes, I wrote the wrong Tap, thanks for the input.
  14. #12
    Jan 2020
    New York
    9
    Thanks for the input, how fast would you go?
  15. #13
    Jul 2002
    Phoenix, AZ USA
    1,735
    57
    213
    I don't know on your Tormach, but most of the time when you are rigid tapping your federate is the pitch, not the pitch times rpm.
  16. #14
    Sep 2006
    SW Wisconsin
    540
    29
    139
    Are you using Path Pilot? If you are and it still follows Linuxcnc then G33.1 is for rigid tapping.
    G33.1K(pitch)Z(depth)
    Ed.
  17. #15
    Jan 2017
    Oregon
    3,064
    612
    2137
    On my VMC's I always use IPM. On the lathe, it's IPR.
    Either one is fine, you just better know which one you are using...
    @OP- get your speeds and feeds better- for 250rpm you should feed at 4.43 rather than 4.4. You can round away the third decimal place, but not the second. 250 is way too slow anyway,
    I'd run that tap no less than 1500 rpm, which would work out to 26.574 IPM feed.
    It's a small tap, and spiral flute taps are more fragile than SP/Plugs. If you machine has peck tapping, take it in 2 or 3 pecks.
  18. Likes Booze Daily, nyjiki liked this post
  19. #16
    Feb 2005
    Akron, OH
    1,880
    294
    1417
    I'd be shocked if your tap even had .65" of flutes. The deepest M2.5 tap on McMaster only goes 1/2" and Balax doesn't have anything deeper in that size either. If you run out of flute, you snap immediately, even if everything else is perfect.
  20. #17
    Jan 2020
    New York
    9
    Used a reduced neck tap, I can clear the depth but I think I took too much depth for an ER Collet holder. Thanks
  21. #18
    Jan 2020
    New York
    9
    I can't peck, i've been looking for someone using a "Q" value in their G84 for their path pilot and I can't find it.
  22. #19
    Jan 2020
    New York
    9
    Yes! Only issue is that I can't find a "Q" value for a standard G84 code that would help me take this depth. I think i'm breaking taps because i'm taking a single pass the tap
  23. #20
    Feb 2005
    Akron, OH
    1,880
    294
    1417
    Which is great, but a spiral flute tap pulls the chips up behind the cut, so once you run out of flutes, they pack up and snap.
    Or keep faffing about looking at your collets. Your choice.
